Leak
Old Oct 17, 2008 | 07:04 PM
Black_TA's Avatar
Car: 1983 Trans Am
Axle/Gears: Stock
Leak
Just bought a 1983 TA, has a heck of a exhaust leak somewere in the manifold area near the O2 sensor, any ideas how I can fing this noisy leak.
Maybe its a cracked manifold.
Old Oct 18, 2008 | 12:58 PM
Rob Wade's Avatar
Car: 89 jaguar xjs convertable
Engine: 89 L98 5.7 TPI
Axle/Gears: 3.23 dana 44
Re: Leak
Check for manifold bolts that have fallen/broken off in the head and y pipe flanges/studs that have rotted out allowing the pipe to come loose. Is the 02 sensor still in place? I've seen them fall out on occasion.
Old Oct 18, 2008 | 06:16 PM
Black_TA's Avatar
Car: 1983 Trans Am
Axle/Gears: Stock
Re: Leak
Thanks for the advice, already checked it seems to me on the top
inner section. Do they make any sealer gasket for this or do I have to
replace the manifold.
Old Oct 18, 2008 | 10:28 PM
nevernamed's Avatar
Car: 87 IROC
Engine: 434
Transmission: TKO600
Re: Leak
You can try using a piece of small diameter hose, put one end in your ear and run the other end around the manifold. Check around each exhaust port and around y pipe flanges, and around the area you suspect is cracked. You can clearly hear exhaust rushing out of any leak through the hose and isolate the location.
Old Oct 19, 2008 | 06:37 AM
Black_TA's Avatar
Car: 1983 Trans Am
Axle/Gears: Stock
Re: Leak
Good Idea,
RS Reaper
Oct 17, 2018 07:52 PM
Mark_ZZ3
May 24, 2018 01:02 PM
Reid Fleming
Oct 10, 2015 09:56 PM
aaron7
Sep 30, 2015 09:15 AM
mfp189
Sep 27, 2015 09:25 AM
