Mufflex Q
Old Nov 24, 2008 | 07:23 AM
joeblue83's Avatar
Car: 1988 Camaro
Engine: 383 Stroker
Transmission: Probuilt 700 R4
Mufflex Q
i am looking at getting probably a 3.5 mufflex. I have noticed that they are reduced to 3 inches to accomodate a cat. How much would this hurt me by having this piped reduced to 3 inches for a cat. I am thinking of not running a cat (yeah I know its illegal) and just welding a 3.5 tube there instead of the 3 inch. Any suggestions?
Old Nov 24, 2008 | 08:28 AM
kcb37's Avatar
Re: Mufflex Q
Look on summit or jegs, pretty sure you can get a 3.5 high flow cat.
Old Nov 24, 2008 | 08:40 AM
joeblue83's Avatar
Car: 1988 Camaro
Engine: 383 Stroker
Re: Mufflex Q
I can't find one bigger than 3 inch
Old Nov 24, 2008 | 09:12 AM
joeblue83's Avatar
Car: 1988 Camaro
Engine: 383 Stroker
Re: Mufflex Q
The 3 inch cat would restrict my flow and it will reduce the pipe size to 3 instead of 3.5
Old Nov 24, 2008 | 09:57 AM
89formula350b2l's Avatar
Car: 92 Camaro
Engine: Dart SHP 406 HSR, LE heads
Transmission: Performabuilt Level 2, Vig 3200
Axle/Gears: S60 373
Re: Mufflex Q
MPe-59920, MPE-60020, MPE-60010 from summit racing
i really dont think that having 12 inches of 3" pipe instead of 3.5 pipe is going to make a significant difference though
Old Nov 24, 2008 | 10:07 AM
joeblue83's Avatar
Car: 1988 Camaro
Engine: 383 Stroker
Re: Mufflex Q
Wow, I have been looking for sometime for one of those. Thanks, anyone have any idea of how the first one flows? I think it should be fine, but someone may have more experience than me with converters
Old Nov 25, 2008 | 11:06 AM
joeblue83's Avatar
Car: 1988 Camaro
Engine: 383 Stroker
Re: Mufflex Q
Whats the difference between a race muffler and a regular muffler. If I run the ultra flo number 17517 with a 3.5 cat, will it be to loud for the streets? Before I blow a lot of money, I want to know if I will like the sound first
Old Nov 25, 2008 | 10:04 PM
Car: 92 Camaro
Axle/Gears: S60 373
Re: Mufflex Q
Listen to Orr's Sound clip....although he has 4" exhaust I dont think it would sound too different. Either that or youtube it.
Old Nov 25, 2008 | 10:56 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
Re: Mufflex Q
I have the 3 1/2" Mufflex system on my car and I run the Magnaflow 3.5" muffler. Not loud at all until you put the pedal to the metal. I run dual cats so I have 3.5" all the way to the "Y". Yes I cut off the 3" pipe on the Mufflex.
Old Nov 25, 2008 | 11:31 PM
TA's Avatar
TA
Car: '88 GTA, 90 Formula
Engine: 5.7 TPI, fed growth hormones
Transmission: 700r4 4u2?
Axle/Gears: 9bolt
Re: Mufflex Q
Random Technology makes a 4" dia inlet/outlet cat converter. No need to be illegal or choke your piping down.
http://www.randomtechnology.com/products.html
TA
Old Nov 26, 2008 | 10:29 AM
joeblue83's Avatar
Car: 1988 Camaro
Engine: 383 Stroker
Re: Mufflex Q
I have decided to go with the 3.5 mufflex with the 3.5 converter. That should flow enough for my need and still be legal, and be quiet enough for the streets.
Old Nov 28, 2008 | 10:05 AM
joeblue83's Avatar
Car: 1988 Camaro
Engine: 383 Stroker
Re: Mufflex Q
Everyone that is reading this that has a ultra flo, how would you rate the sound quality and how loud?
88SS6SPEED
Nov 11, 2015 07:05 AM
FormulaJoe
Jan 1, 2002 11:47 PM
CHCKLS
Nov 2, 2001 04:17 AM
Gta-Paladin
Dec 7, 2000 09:25 AM
