do i need a cat
Old Jan 7, 2009 | 11:19 AM
marshall1's Avatar
Car: 87 camaro
Engine: 305 soon to be a 350
Axle/Gears: 383's i think?
do i need a cat
i have a 1987 camaro carb 305 ho and i live in new hampshire i want to know if a have to have a cat converter to pass inspection. Cause i know i don't have to pass emissions. If i don't i'm gonna take it off so my car is louder
Old Jan 7, 2009 | 11:23 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: do i need a cat
Emissions are probably a good thing in the long run. I doubt that cat removal will make your ride significantly louder. A better approach might be a new muffler or catback. A search will provide brand names.
JamesC
Old Jan 7, 2009 | 12:29 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Re: do i need a cat
Yes, a catalytic converter is required by federal law to be on all street cars that came with one, that are driven in the United States. That means all thirdgens.
Old Jan 7, 2009 | 01:13 PM
91camaro372's Avatar
Car: 91 Camaro RS
Engine: 3.1L v6
Axle/Gears: 2.73(for now) posi disc from 95 Z28
Re: do i need a cat
You could always gut the cat. It will do the same as removing it but is still in place so you cant get in trouble for it. The only thing is that if you do that it probably wont pass emissions. It wouldnt matter if you have historic tags on it but its up to you...
Old Jan 7, 2009 | 01:18 PM
blkfirebird91's Avatar
Car: 1991 Trans Am
Engine: 305tbi to 350 carb'd
Axle/Gears: Stock
Re: do i need a cat
if you want your car louder take the muffler off and keep the cat when i lived in az idk but there emissions are weird i passed out there on 7 cylinders i got home looked at everything and i had a spark plug wire cut but you do need a cat to pass but like i said you want it louder take the muffler off and run dual pipes out the back
Old Jan 7, 2009 | 01:19 PM
Stephen's Avatar
Car: 87 GTA
Re: do i need a cat
Even for those states not requiring emissions testing, the cat still has to be on there by FEDERAL law.
Old Jan 7, 2009 | 01:34 PM
Car: 1991 Trans Am
Axle/Gears: Stock
Re: do i need a cat
true it is a federal law so my advise is you should just keep it on
Old Jan 7, 2009 | 03:12 PM
evoluzione1's Avatar
Car: 88IROC vert and a 83 w/evo body
Engine: 400 and 350
Transmission: T56 and 700R4
Axle/Gears: 323 and 373
Re: do i need a cat
Removing the cat will not make the car loader but will give it the cackle sound. Removing the cat will however make the car smell fumey and you will have the exhuast stick on you from time to time. Trust me not good, that's why I put a cat back on both my camaro's, to much fumes
Old Jan 7, 2009 | 09:00 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: do i need a cat
yea, the car will stink without the cat. I have run my car without cats for the last 5 years or so and im tired of the smell. Im in the process of putting cats back on. You only loose a little power, and im hoping it will quite the car a little more.
Old Jan 8, 2009 | 12:31 PM
Kevin91Z's Avatar
Re: do i need a cat
Gutting the cat is the same as removing it in the eyes of the law. Yes you will get in trouble for it, if you're caught.
LT1Formula
Oct 8, 2015 08:34 PM
jaridjohn
Oct 5, 2015 07:01 AM
