After Cat pipe
Old Jan 9, 2009 | 12:05 PM
zride91's Avatar
Car: 1991 Z28
Engine: 383 TPI
Transmission: 700R4 w/2800 stall
After Cat pipe
I have a set of Dyno Don headers, the single cat y-pipe has a 3" outlet. I am going to get a Magnaflow 3" direct fit Cat w/ the bracket and ball fitting on the outlet side. I have a 3" Borla cat-back, but the Borla system does not actually connect right to the Cat. Is there anyone who sells a 3" STAINLESS pipe that would go between the Cat and the Borla system with the appropriate fitting to the Cat and correct bend in it?
The Borla system came with (3) different front pipes for the different factory exhaust sizes, you were supposed to just cut the OE pipe and slip their system on. My old system was for a 305, it was 2.25" or 2.5".
Old Jan 11, 2009 | 09:35 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Re: After Cat pipe
Because you have a custom setup, I doubt anyone is going to have something that will bolt on.
You have to take the car to a good muffler shop and have them make the connection.
LT1Formula
Oct 8, 2015 08:34 PM
jaridjohn
Oct 5, 2015 07:01 AM
