exhaust
Car: 1991 firebird formula
Transmission: auto.
Axle/Gears: ?
exhaust
ha! i was wanting to put a new exaust system on my 1991 firebird and i hear a lot of talk about long and short headers ,x pipes and y pipes ! what is the best way to for gas mileage ,and power?
re: exhaust
i have a question about afr heads.i am building a chevy 406 motor and i want afr 210 heads,but the suplier told me that the plugs are not straight.is there a big diffrence between the straight and the angled plugs.?
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
re: exhaust
Long headers are for high rpm performance and exhaust scavenging, they have bad ground clearance on these cars and are not emissions legal. Generally these are race only parts.
shorties fit in the stock location, are a massive improvement over stock and work very well for upwards of 500 horsepower, more than enough for most cars. They also offer much better ground clearance and can be had in emissions legal setups.
It is done in this case because of relocated vavle locations in the heads.
sometimes headers clearance issues arise with angle plug heads, but not always. It depends a lot on what headers you are using.
Last edited by //<86TA>\\; Jan 25, 2009 at 02:54 PM. Reason: Automerged Doublepost
Transmission: auto.
Axle/Gears: ?
re: exhaust
ok! so what i am hearing is that for a stock motor i need to run short headers and a y- pipe. For big hp you need long headers and straight exaust,wright?
Car: 86 Trans Am
re: exhaust
thats pretty much the case, In these cars for he most part, its not worth the aggravation trying to use LT headers on a street car. They hang too low, making a y-pipe is difficult, and they are not emissions/street legal.
Car: '88 GTA, 90 Formula
Engine: 5.7 TPI, fed growth hormones
Transmission: 700r4 4u2?
Axle/Gears: 9bolt
Re: exhaust
TA
david068513
Sep 18, 2015 10:36 AM
