bbc headers for sbc
Old Jan 25, 2009 | 10:49 PM
90-irocdx3's Avatar
Car: 1990 iroc z
Engine: LSX 376 F1A
Transmission: 4l60e
Axle/Gears: 12 bolt 3.42
bbc headers for sbc
i was just looking at some pictures of the hooker big block lt headers for our cars and i like how the wrap around the bottom of the car. would big block headers fit the sbc with minor mods or what would be needed to get these headers to work? i already have dougs lt headers just debating weather to put them on yet.
Old Jan 25, 2009 | 11:12 PM
customblackbird's Avatar
Car: 87 TA clone
Engine: 70/70 Turbo 5.3 LS
Transmission: bullet proof 2004R
Axle/Gears: ford 8.8, 3.55 gears
Re: bbc headers for sbc
big block heads have the same exhaust port configuration as the LS motors... the exhaust ports are evenly spaced from eachother... SBC heads are totally different. the have the outer 2 exhaust ports towards the outside and the 2 inner ports right next to each other... inother words they will not work. ud have to redeisgn the flange and primaries to fit. also BB headers are usually not smaller than 2" in primary size DIA. this is usually too big for a SBC... standard SBC primary DIA is 1 5/8" or 1 3/4". 1 3/4" being the higher flow for HIGH reving 350/355 or 383/400/427 SBC.
this is SBC exhaust ports
http://www.morethanjustpower.com/par...load/164_1.jpg
this is BBC exhaust ports.
http://performanceparts.com/performa...head_11302.jpg
see the diff?
Old Jan 25, 2009 | 11:41 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Being evenly spaced is the only similarity. They are not the "same".
Old Jan 26, 2009 | 12:20 AM
Car: 87 TA clone
thats what i was referring to. should said "same"
Old Jan 26, 2009 | 12:25 PM
five7kid's Avatar
Well, should "not" say same, should at most say "similar".
I can post pics of BBC gasket on LS1 manifold if desired.
Hotrodboba400
Dec 10, 2019 07:07 PM
Loudnproud86
Jul 14, 2016 12:59 AM
13sec83trans
Carburetors
22
Nov 28, 2015 09:26 PM
dimented24x7
Sep 6, 2015 03:51 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
