vortec header question
Old Feb 8, 2009 | 11:06 AM
watman02's Avatar
Car: 91 Z28
Engine: LB9
Transmission: 5 speed
Axle/Gears: 3.73 limited slip stock
hey guys i have an lb9 car with Flowtech 31102FLT headers (saw no power increase by the way) i have come into a set of vortec heads and plan to have a 350 built to with them and use the TIPS big mouth system my question is will my headers still work with the vortec heads or do i have to replace them?
i know i should replace them with somthing bigger but i need to know if
they will bolt up?
thanks
Old Feb 9, 2009 | 03:56 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Re: vortec header question
Your TPIS intake will not work with Vortec heads. You need the Vortec TPI intake from Scoggin Dickey.
Yes your headers will fit fine.
Old Feb 9, 2009 | 06:31 PM
TA's Avatar
TA
Car: '88 GTA, 90 Formula
Engine: 5.7 TPI, fed growth hormones
Transmission: 700r4 4u2?
Axle/Gears: 9bolt
The headers will bolt up, but spark plug/boot access and clearance could be a problem.
TA
MustangBeater20
Oct 29, 2022 09:20 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
tricky1
Aug 23, 2015 01:17 PM
redmaroz
Aug 16, 2015 11:40 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
