Ideal Pipe Size for mild TPI motor
Old Feb 10, 2009 | 09:46 PM
86z28iroc-z's Avatar
Car: 86' Z28 Camaro
Engine: 357 TPI -- Dart Heads -- Voodoo Cam
Transmission: Built 700r4
Axle/Gears: 3.23 Posi
I recently put hedmann shorty headers on a mildly rebuilt 350 tpi motor and they came with a 2.5" y-pipe, the only two y-pipes that come with hedmann headers are 2.5".
Is it even worth it to mate this y-pipe up to 3" piping all the way back, or would it actually flow better even though the y-pipe is only 2.5". or would it hurt the flow by changing from 2.5" to 3" and thus slowing down the scavanging effect/flow of exhuast?
Should I...
A> cut the end of the y-pipe off and weld a new 3" end on, continuing on with the 3"
B> leave it be and just get the 3" it'll flow about the same
C> screw it all and just get new mandrel bent 2.5" the 3" won't be worth it on a mildly built 350 with a tpi intake
Old Feb 11, 2009 | 04:28 PM
David 91RS/Z28's Avatar
Re: 2.5" y-pipe to 3" inter. pipe?
If the collector on the y-pipe is only 2.5", then I would cut this off and weld on a 3" collector. Flowmaster makes y collectors that come in 2.5" inlets and 3" outlet. From there finish running 3" all the way back. I would recommend using Hooker or Magnaflow for a muffler. Or just get their 3" catbacks. Good luck!
Old Feb 12, 2009 | 09:16 PM
Car: 86' Z28 Camaro
Re: 2.5" y-pipe to 3" inter. pipe? Where to get?
Edited.
Old Feb 16, 2009 | 01:07 PM
Car: 86' Z28 Camaro
Re: Ideal Pipe Size for mild TPI motor
Reading over all the stickies and looking at other posts and sites, i've noticed that a 3" pipe is ideal for 350 that peaks between 5500-6500 rpms, so knowing that, wouldn't a 2.5" pipe be better for a mild 357 tpi which peaks between 3500-4500 proven on a dyno? Max HP was @ 4300 and Max TQ was @ 3500.
2.5" fully mandrel bent with headers would most likely be ideal? Am i thinking right here?
Old Feb 16, 2009 | 02:11 PM
joeblue83's Avatar
Car: 1988 Camaro
Engine: 383 Stroker
Transmission: Probuilt 700 R4
yes a 2.5 y pipe with the 3 inch collector and 3 inch catback is perfect for your situation. Remember that a 3 inch catback flows enough for 370 horse.
So you should be fine
Old Feb 16, 2009 | 02:26 PM
Car: 86' Z28 Camaro
In my understanding a bigger pipe would actually hurt performance in the low-mid range which my car makes most of it's power, it's only 230hp to the wheels and 310tq in the 3000-4500 rpm range. That being made with the stock crush bent piping and no muffler and no cat.
My thoughts from reading the stickies would that a 2.5" collector and a fully 2.5" mandrel system would be a more ideal system than a 3" system. But everyone is saying 3" would be better going against what the stickies are showing.
drewdock87
South Central
Aug 18, 2015 09:02 PM
zracTA
Interior Parts Wanted
Aug 15, 2015 12:10 PM
Sanjay
Aug 12, 2015 03:41 PM
knight72
Aug 10, 2015 09:32 PM
squiggy2
Aug 9, 2015 09:30 PM
