Vacuum line on the Exhaust manifold/y-pipe?
Old Feb 12, 2009 | 03:51 AM
camaro87-alex's Avatar
Car: 1987 Chevrolet Camaro SC
Hi there..
I am in the middle of an TPI swap on a 1987 Camaro. Carbed to TPI.
I have a Vacuum line going from the y-pipe more close to the passenger exhaust manifold...Where should this be connected?..I have forgotten how it was on my carbed engine.
Old Feb 12, 2009 | 07:33 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Vacuum line on the Exhaust manifold/y-pipe?
Originally Posted by camaro87-alex
Hi there.. I am in the middle of an TPI swap on a 1987 Camaro. Carbed to TPI. I have a Vacuum line going from the y-pipe more close to the passenger exhaust manifold...Where should this be connected?..I have forgotten how it was on my carbed engine.
The carbed engine had an EFE valve, which the TPI engine won't have. Instead, between the manifold and Y-pipe there'll be a spacer instead of the valve. There a pic in the following link:
https://www.thirdgen.org/forums/hist...-manifold.html
JamesC
Old Feb 12, 2009 | 12:23 PM
JamesC
Ok...Thanks alot for the info..So I need to get an spacer then?..Or can I just block the hose that comes out of the EFE valve??
Old Feb 12, 2009 | 01:24 PM
JamesC's Avatar
IIRC, the default for the valve is open, so you could simply remove the hose altogether.
JamesC
theshackle
Mar 5, 2017 06:37 PM
Jote4805
Aug 25, 2015 06:11 PM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
apie2546
Aug 10, 2015 05:43 PM
