SMOG removal help question
Old Feb 16, 2009 | 08:12 PM
FireBirdKnight's Avatar
Car: 1985 TransAm
Engine: 5.0L TPI
Transmission: 700R4 auto
Axle/Gears: 3.27 BorgWarner
so i had the air pump and tubing removed and stock logs welded shut, but id like to keep my cat on so i dont get an annoying rasp in my exhaust
but i heard removing the air pump will reduce the cats life and most likely ruin it within a few hundred miles
any replacement cats without smog pump provisions?
Old Feb 16, 2009 | 10:49 PM
89ROC-Z's Avatar
Car: 89 IROC-Z
Engine: 370 LSX, LS3 Top End
Transmission: Built T-56
Axle/Gears: 9" Aluminum Center 3.89's
Re: SMOG removal help question
Have you noticed that cat delete cars have a rasp? I've never heard one in real life, just Brisk's video of his cat delete http://www.youtube.com/watch?v=wi40rYz2lPU
Old Feb 16, 2009 | 11:45 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
If you want to remove smog from the air, the best way is to leave the parts on there and let them do their job.
Thank you for at least leaving the cat on there.
Yes you can get cats that dont use the AIR tube. Magnaflow makes them for sure, and I believe Random Tech and Catco should as well.
Your cat wont fail immediately without the AIR going to it. It just wont do its job as well.
Old Mar 14, 2009 | 09:38 PM
theimpaler68's Avatar
Car: 86 T/A & 88 GTA
Engine: 305 LB9 TPI & 350 LO5 TPI
Transmission: Jasper 4L60 x2
Axle/Gears: 2.77/posi LSD & 2.73/posi LSD
i ran my car 2 years now with AIR taken out and i never had a problem. i am now replacing entire exhaust because i broke a y pipe to manifold bolt and with tax money said why not. got hooker 2055's new cat from magnaflow and cat back from magnaflow. the cat and headers have AIR provisions just capped it off in case in the future i might put the stuff on. thinking of moving out of florida. just nice to have options
Frozer!!!
Jan 19, 2024 04:55 PM
redmaroz
Aug 16, 2015 11:40 PM
gta power
Aug 13, 2015 06:15 AM
3rdgenparts
Aug 8, 2015 07:09 PM
mustangman65_79
Aug 7, 2015 09:55 PM
