Removing exhaust manifold to y-pipe studs
Old Feb 23, 2009 | 03:06 PM
gtaproject's Avatar
Car: 88 GTA
Engine: 305 LB9
What's the preferred method. I tried the 2 nut technique, but the top nut just spins and wont tighten against the bottom nut (threads are pretty bad).
Why do they make the bottom of the stud round? Seems like a good idea to make flat edges so you could get a grip. Thanks
Kevin
Old Feb 23, 2009 | 03:18 PM
89ROC-Z's Avatar
Car: 89 IROC-Z
Engine: 370 LSX, LS3 Top End
Transmission: Built T-56
Axle/Gears: 9" Aluminum Center 3.89's
Re: Removing exhaust manifold to y-pipe studs
I soaked mine in PB Blaster, the next day they turned out with a smaller visegrip. Trust me that PB Blaster stuff is amazing, you can see it soak into the threads and surronding metal.
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
transaero
Aug 31, 2015 01:14 AM
Nj1987
Aug 19, 2015 08:26 PM
timonator
Aug 11, 2015 09:56 PM
3rdgenparts
Aug 8, 2015 07:09 PM
