02 sensor question
Old Mar 19, 2009 | 12:38 AM
IROCJoyce's Avatar
Car: 1987 IROC
Engine: 350 Gm H.O
Transmission: 700r4 built
Axle/Gears: 3.42 Locker
02 sensor question
I will be putting long tube heads on my car in a couple months and had a couple questions about the 02 sensor. My headers didn't come with a 02 bung and they are ceramic coated so I don't want to have to grind off the coating and weld in a bung and have to recaot the header again. So what I am asking is that if it would be alright if the o2 sensor was just put into the exhaust under the car? Does it matter if I just extend the sensor wire and place it farther down the exhaust? Will it matter if water and road grime sloshes onto it? And lastly will it read funny if I put it about a 6 inches give or take down the exhaust from the header? On the hooker instructions it says extend the o2 sensor wire so I am guessing there isnt much too worry about.
Old Mar 19, 2009 | 06:47 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Put it as close to the collector as you can.
Old Mar 19, 2009 | 07:52 PM
IROCJoyce's Avatar
Car: 1987 IROC
Engine: 350 Gm H.O
Re: 02 sensor question
Thanks for your response. I am assuming that is the answer to all of my questions.
Old Mar 20, 2009 | 02:12 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Yes you can put the O2 sensor in the y-pipe. I highly recommend using a heated O2 sensor, so it stays hot enough to read accurately.
You'll have to to get the info on hooking up a heated O2 sensor in this forum.
Frozer!!!
Jan 19, 2024 04:55 PM
9192camaro
16
Feb 3, 2019 12:21 AM
Caspar
Jun 19, 2016 11:19 PM
redmaroz
Aug 16, 2015 11:40 PM
squiggy2
Aug 9, 2015 09:30 PM
