Y Pipe And Headers!! Question
Old Mar 23, 2009 | 09:59 PM
burnrubber9095's Avatar
my buddy just gave me some shorty headers off his T/A and theyre going in my 90 camaro rs tbi with ac. since i cant use the stock y pipe im going to but the hedman y pipe from summit part number 17470. ive read some posts and they say y pipes are different and made for different headers but in the description it says it will fit standard shorty style headers. Does anyone know if this y pipe will work. also is there anyone that could give me instructions on putting headers on like what i have to do i have ac and the best location to get at the bolts? also any parts i need to remove, thanks guys id rlly apprecitate an answer
Old Mar 25, 2009 | 02:03 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Re: Y Pipe And Headers!! Question
What year is his T/A? You can only use 82-92 thirdgen headers. Other year f-body headers will not fit.
And unless those headers are Hedmans, then no the Hedman y-pipe will not fit.
Old Mar 25, 2009 | 06:44 PM
his T/A is an 87 and the y pipe says it will fit hedman headers and standard shorty headers on thirdgens
Old Mar 25, 2009 | 06:50 PM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
That y-pipe still sucks. MAC makes a couple of better ones. Either way, you'll still run into problems. Good luck.
Old Mar 25, 2009 | 06:59 PM
if you are going to say i will run into problems could you at least be a little more specific
Old Mar 26, 2009 | 01:31 AM
Kevin91Z's Avatar
Think about this: How can one y-pipe fit Hedman headers AND every other set of shorty headers, at the same time?
LT1Formula
20
Nov 14, 2015 12:02 AM
hectre13
Sep 8, 2015 03:38 PM
Out-Cast
Aug 22, 2015 07:49 PM
redmaroz
Aug 16, 2015 11:40 PM
mustangman65_79
Aug 7, 2015 09:55 PM
