Magnaflow y-pipe
Old Mar 26, 2009 | 11:09 PM
FueledSoul's Avatar
Car: 84 camaro, 88 trans am, 98 camaro
Engine: Modded , stock, LSX modded
Transmission: 700r4, 700r4, t-56
Axle/Gears: 327, 308, 373
Magnaflow y-pipe
If anyone has used this is the inside of its construction slug free. just wondering what the inside looks like some y-pipes iv seen look horrible
Old Mar 26, 2009 | 11:14 PM
BlKnt18's Avatar
Car: 1989 Camaro Iroc-Z
Engine: 5.7 L98 Carb. Alum. Heads
Axle/Gears: 3.08 Limited Slip
Re: Magnaflow y-pipe
I just put one of those on. I used a 3in dual in 3in single out but anyways they do a lap joint weld so you done see any slag. So It flows very well going the one way but then going out is like any other slip joint.
FormulasOnly
Jul 23, 2018 08:47 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
