Cutout?
Old Apr 6, 2009 | 11:27 PM
leek157's Avatar
Car: 95 SHO. 87 IROC red 69 Vette blue
Engine: 3.0 Yamahammer.5.7 TPI L98, 350
Transmission: mtx4 ,700r4, 4speed,
Axle/Gears: 3.27, 3.73
Cutout?
Hi, so ive got hooker 2055's and a flowmaster catback and where the cat should be im going to put a cutout there, any tips or tricks to doing this, the hooker y pipe has a 3 inch outer diameter so a 3 inch inner diameter should fit over it and the flowmaster has a flange to bolt onto the cat (which a pipe would still have to go between the cutout and the catback) what else should i be looking into or looking for. anyone else done this? if you have some pics of your setup would be awesome.
Old Apr 7, 2009 | 12:16 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Re: Cutout?
Be a responsible hot rodder and leave the cat alone.
I put my cutout in the I-pipe just before it goes over the axle. That way when its open the exhaust goes straight out the back instead of having to go up and over into the muffler.
Old Apr 7, 2009 | 12:37 PM
leek157's Avatar
Re: Cutout?
I was going to leave it on there but I did not feel like cutting it off the old y pipe and fitting it onto the new one, so instead of just putting a pipe there I thought I would make it a bit more interesting and put a cutout there.
Old Apr 7, 2009 | 03:20 PM
89ROC-Z's Avatar
Car: 89 IROC-Z
Engine: 370 LSX, LS3 Top End
Transmission: Built T-56
Axle/Gears: 9" Aluminum Center 3.89's
Re: Cutout?
I got the 2055s with a QTP 3" cutout right on the Y. I just had the cutout expanded to 3"i.d. to slip over the Y.
Pics in my sig link of how i made the cat bend work with the cut out. Name:  S8001058.jpg
Old Apr 7, 2009 | 10:50 PM
leek157's Avatar
Re: Cutout?
that looks very similar to what i was thinking of doing just with a flange on one end to bolt to the rest of the exhaust and the hanger by the cat
86White_T/A305
Mar 6, 2016 01:48 PM
formula_novice
Sep 5, 2015 03:58 AM
Josh 91RS
Jan 22, 2001 01:23 PM
Mike Harvey
Dec 7, 2000 02:52 PM
