Header install
Old Apr 9, 2009 | 01:35 PM
kkingsrulee's Avatar
Car: 1990 Camaro RS
Engine: V8 305 TBI
Transmission: W/C T5
Axle/Gears: 3.08
Header install
I'll be getting the 2055's off jegs in about week, I'm just clearing up everything so the install will go off without a hitch.
It may sound a bit noob, but I don't know, everything will bolt up right? from the headers to the y-pipe that comes with it? No welding required? And a cat will bolt to the end of the y-pipe correct?
Also, I'll lift up my car and look later today but does the y-pipe that comes with the 2055's follow the same path of the stock exhaust? I'm pretty sure mine goes off to the right and then connects to the stock cat, does that sound right? There won't be any clearance issues with the 2055 y-pipe correct? No oil pan or tranny issues?
Thanks guys
1990 RS 305 T5
Old Apr 9, 2009 | 01:46 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Header install
Also, I'll lift up my car and look later today but does the y-pipe that comes with the 2055's follow the same path of the stock exhaust? There won't be any clearance issues with the 2055 y-pipe correct?
Yes, everything bolts up. The Y, however, doesn't have a flange, so you'll either have to purchase a slip-fit cat (Summit CTO-9118) or modify. Same path, no clearance issues.
JamesC
Old Apr 9, 2009 | 01:58 PM
Car: 1990 Camaro RS
Engine: V8 305 TBI
Axle/Gears: 3.08
Re: Header install
Thanks alot, but I only need a flange for the y-pipe-cat connection correct?
I was planning on buying a slip-fit cat anyways so no problems there.
Old Apr 9, 2009 | 06:07 PM
89ROC-Z's Avatar
Car: 89 IROC-Z
Engine: 370 LSX, LS3 Top End
Transmission: Built T-56
Axle/Gears: 9" Aluminum Center 3.89's
Re: Header install
Yessir! Im in the process of getting mine installed aswell. Everything will bolt up fine, get a 3"id cat and then a jegs lap-joint clamp, everything should be fine and dandy. Look down the exhaust forum a bit and look for my thread "Those with hooker 2055s come on in!" ALOT of info there.
sweet_87_iroc
Sep 25, 2015 10:01 PM
Wesly_66
Aug 26, 2015 09:55 PM
mdtoren
Aug 23, 2015 12:52 PM
theurge
Aug 21, 2015 12:46 PM
drathaar907
Aug 6, 2015 04:20 PM
