dual exhaust finally done
Old Apr 23, 2009 | 06:00 PM
mark 87gta's Avatar
Car: 87 trans am gta
Engine: 355 ci
Axle/Gears: 327 for now work in progress
this my 87 gta with its 3 inch dual exhaust ground clearance is awsome it consists of heddman long tubes universal summit x-pipe and flowmaster super 44's dont get me wrong it wasnt a direct bolt on but i had to do some cutting to get ot right but the results are well worth it and it is very loud will try and get sound clips this weekend
Attached Thumbnails dual exhaust finally done-034.jpg   dual exhaust finally done-035.jpg   dual exhaust finally done-036.jpg
Old Apr 23, 2009 | 07:47 PM
383roller's Avatar
Car: '86 Iroc-z
Engine: 385 stroker, vortecs, demon 750
Transmission: G-Force T-5
Axle/Gears: 9-bolt, 3.27s
Re: dual exhaust finally done
please put bigger pictures, i am wanting true duals with dual chamber mufflers i want to see the ground clearance
Old Apr 24, 2009 | 05:51 AM
mark 87gta's Avatar
Engine: 355 ci
yeah sorry thoes pics were taken with my i phone
Old Apr 25, 2009 | 11:07 PM
newts25th's Avatar
Car: 92 camaro 25th anniversary
Engine: 305 tbi
Transmission: automatic
Where is the sound clips? How are the hedman long tubes? this is the setup that I wanted to do minus the x-pipe. How much ground clearance do you have???
Old Apr 26, 2009 | 10:44 PM
hotrod85z's Avatar
Car: 1986 camaro
Engine: 5.7 HSR
Transmission: 700-r4
Axle/Gears: 3:42 auburn
how do they fit around the heads? i cant get enuff room to screw in my #3 sparkplug do u have a pic of the driverside? thanx Mark!!!
Old Apr 27, 2009 | 07:34 PM
mark 87gta's Avatar
Engine: 355 ci
they are long tubes fitment was ok for the spark plugs had to grind the k-member and use a mini starter ground clearance is excellent lowest point is the mufflers and that is still 4 inches trying to get some sound clips but i just had carpal tunnel surgery so its kinda tough right now but it is very loud but my motor has 12.5.1 compression and big roller cam
Hotrodboba400
Dec 10, 2019 07:07 PM
Dyno Don
Jan 24, 2016 08:24 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
IROCZDAVE (88-L98)
Sep 2, 2015 08:49 AM
IROCZDAVE (88-L98)
Sep 2, 2015 08:43 AM
