"over exhausting" i guess its called
Old Apr 24, 2009 | 07:42 PM
Floorman279's Avatar
i believe it is possible but just double checking. say i have a stock 215 hp 350 and put hooker super comp headers on it will that actually do the motor bad? sticking with that stock 350, is a complete 3" cat back too much for it also and will that decrease hp? is 2.5" more reasonable.
Old Apr 24, 2009 | 08:45 PM
89ROC-Z's Avatar
Car: 89 IROC-Z
Engine: 370 LSX, LS3 Top End
Transmission: Built T-56
Axle/Gears: 9" Aluminum Center 3.89's
Re: "over exhausting" i guess its called
Absolutely not. Read all the pages of the backpressure sticky. I have hooker 1 5/8s shorties, 3" Y, 3" cut-out, and 3" cat back. The factory Y on my iroc is 3", so y not go 3" all the way back.
Old Apr 24, 2009 | 08:54 PM
Stephen's Avatar
Car: 87 GTA
Because as the exhaust travels back, it cools & condenses, making it smaller pulses.
To maintain velocity, stepping down in size & going smaller can be a good thing sometimes,
Old Apr 24, 2009 | 09:18 PM
89ROC-Z's Avatar
Car: 89 IROC-Z
Your very right Stephen. Just like a long water pipe, you need to tighten up the diameter the longer it is to keep good water velocity. BUT, IMO i think the 305 needs room to breath, also if I ever upgrade my exhaust is pretty good for some high hp.
Old Apr 24, 2009 | 09:26 PM
so you can really go any thickness with a mildly modified motor but you should look into it a little bit if its a stock motor?
Old Apr 27, 2009 | 06:34 PM
one92rs's Avatar
Car: SOLD!!!!!
i went with hooker headers(1 5/8) and a hooker y pipe. i went with a magnaflow catback. im sure it is hurting my little carbed 305. but i know that i am going to use it well when i get my vortec engine built and installed/
Linson
Oct 24, 2025 02:00 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
bschmale66853
Sep 30, 2015 08:11 PM
