Complete Exhaust for 383
Old May 24, 2009 | 08:19 PM
tyler92's Avatar
Car: 91 Camaro RS
Engine: 5.3
Transmission: Th400
Ok guys , i've been searching around for about 2 hours , and i'm lost. I need a full exhaust setup for my 383 that i'm dropping in soon. I need everything including headers. I do not need A.I.R. And i don't mind having or not having a cat. I would really appreciate it if someone could give me part numbers so i could have a complete exhaust . Thanks
-Tyler
Old May 25, 2009 | 09:51 AM
tyler92's Avatar
Car: 91 Camaro RS
Engine: 5.3
Transmission: Th400
Re: Complete Exhaust for 383
bump. anyone?
Old May 25, 2009 | 09:55 AM
WASyL's Avatar
Car: 1988 Pontiac Firebird
Engine: 305 LT1 intake&heads
Transmission: TH700r4
Axle/Gears: 3.73 10bolt GM
any price range ? do you mind cutting and denting some body parts
best regards
Old May 25, 2009 | 09:56 AM
tyler92's Avatar
Car: 91 Camaro RS
Engine: 5.3
Transmission: Th400
best regards
I would like to keep it under 1000
Old May 25, 2009 | 12:37 PM
tyler92's Avatar
Car: 91 Camaro RS
Engine: 5.3
Transmission: Th400
Ok basicallly from what i understand , i need the headers(no a.i.r) with a matching y-pipe. And a cat back. And what if i dont run a cat? Wouldnt there be a gap between the y-pipe and the cat back setup? Or should I just run a Cat?
Old May 25, 2009 | 12:53 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
no reason not to run a cat, it will keep the car from smelling, keep it somewhat legal, and you wont miss the 5hp they take up.
Headers, hooker 2055's are the most common, probably the best fitting big name aftermarket headers. However they are only 1 5/8 primaries, a little small for a larger engine like a 383.
DynoDon here on tgo sells arguably the best shorty header setup available for the 3rd gen. 1 3/4 primary and 2.5" y, ceramic coated and the worlks. They are expensive though, probably blow most of you exhaust budget on them alone.
As for the cat back, magnaflow makes a good one, just search on jegs or summit or other similar sites for it. Mufflex sells the largest kits, 3.5" and 4" single tube systems, but again they are about 700bux.
You can probably get the hooker 2055's, uncoated, and a flowmaster or similar 3" catback, and a universal high flow cat for under a grand.
however coated headers are really the way to go, hands down. well worth the extra money
Old May 25, 2009 | 01:07 PM
Stephen's Avatar
Car: 87 GTA
Contact Dyno Don here on TGO for his headers. He can do them with or without A.I.R. tubes.
Run a Magnaflow cat. It costs you like what? 3 hp & keeps the car street legal & the air clean.
As for cat backs & mufflers.....A lot of that depends on personal preference of sound.
Yes, some flow better than others, but in the end, it usually falls on personal preference for sound. I like my LS1 TSP Rumbler Magnaflow cat-back on my L98.
Quiet at cruise, just a touch of it being there, but when I stab the throttle, you KNOW its there.
Here is a link to my Photobucket with several videos, bot from inside & outside the car. Photobucket Link
Old May 25, 2009 | 04:00 PM
tyler92's Avatar
Car: 91 Camaro RS
Engine: 5.3
Transmission: Th400
So the rumbler is a direct fit on our cars?
Old May 25, 2009 | 04:03 PM
Stephen's Avatar
Car: 87 GTA
No. It is a LS1 4th gen kit that like any other, will need tweaking to fit our cars.
Old May 25, 2009 | 04:06 PM
tyler92's Avatar
Car: 91 Camaro RS
Engine: 5.3
Transmission: Th400
what kind of mods did you have to do?
Old May 25, 2009 | 04:16 PM
Stephen's Avatar
Car: 87 GTA
The previous owner had it installed for him, so I'm not 100% sure.
I do know the hangers are different on ALL 4th gens and the intermediate pipe is a little different, since 98+ cars have (basically) a dual exhaust in front of their dual cats, then a Y-connection just behind the tranny.
From underneath, I don't see any major cutting/welding/tweaking done.
I know mine isn't (by far) the first 3rd gen with a LS1 cat-back on it.
Old May 25, 2009 | 04:23 PM
tyler92's Avatar
Car: 91 Camaro RS
Engine: 5.3
Transmission: Th400
Ok thanks for the info, i can look at the sticky for catback advice. But if ne1 wants to throw something in im glad to hear it.
Terrell351
Jun 13, 2021 01:13 PM
Vintageracer
Jan 10, 2020 05:33 PM
Casey Meyers
Mar 2, 2016 10:46 AM
Reddeath210
Oct 6, 2015 08:20 AM
KO1
Aug 31, 2015 06:31 PM
