New exhaust help
Old May 25, 2009 | 08:42 PM
servo2055chevy's Avatar
Car: 1988 Camaro Base model
Engine: 305 LO3 5.0L V8 TBI
Axle/Gears: 10Bolt Rear, Not sure the gearing
New exhaust help
I want to put a flowmaster muffler on my camaro, the car has the stock exhaust and I want to keep it stock except for the muffler. Do I need a welder to put on a new muffler? I don't have one so is there anyway I can do it w/out welding it. and also when I cut it off do I cut the stock muffler up at the casing? please help
Old May 25, 2009 | 10:07 PM
kkingsrulee's Avatar
Car: 1990 Camaro RS
Engine: V8 305 TBI
Transmission: W/C T5
Axle/Gears: 3.08
Re: New exhaust help
Anyone that sees the opportunity to correct me please do.
I'm pretty sure most mufflers have to be welded, I'm not aware of any that are "Slip fit", I suppose you could sort of jury rig a set up, the intermediate pipe from the cat to the muffler could be bigger than the muffler inlet and you could perhaps exhaust clamp it down, I doubt this would be very effective though.
I don't think it would be very expensive at all to have a muffler shop weld it in. I'd say definitely less than $50.
Old May 25, 2009 | 11:09 PM
Screamin86's Avatar
Car: 86 Trans Am,03 Yukon,92 Z28
Engine: 5.3, 5.3, lb9
Transmission: th350,4l60e,700r4
Axle/Gears: 3.73,3.73,2.73
you can deffinately clamp exhaust together! all a shop would do is wxpans the pipe to fit over one another and then weld. sometimes the mufflers are made to slip over lets say a 2 1/2 pipe. i put a flowmaster 10series on my buddys f150 and we used clamps.
Old May 26, 2009 | 12:49 AM
LB9Iroc87's Avatar
Car: 1987 Iroc-Z28
Axle/Gears: G92 3.23, G80, J65 disc
you could definetly put it on with clamps from Auto Zoo or a muffler shop, but if you have about 50 bucks lying around take it to the muffler shop and see what they can do, or if you have a welder accesible then that would be best, if your know what your doing.
zapr
Jul 27, 2018 06:03 PM
PurelyPMD
May 5, 2016 04:57 PM
86White_T/A305
Mar 6, 2016 01:48 PM
1992Z28!
Nov 19, 2015 07:33 AM
david068513
Sep 18, 2015 10:36 AM
