Oxygen Sensors
Old Jun 11, 2009 | 11:26 PM
ngonnelly's Avatar
Car: 1990 Camaro IROC-Z28
Engine: 5.7L 350cid
Transmission: auto
Axle/Gears: i think 3.42
Oxygen Sensors
everthing i need to knwo about them what they do and how meny are in a 90 iroc z
Old Jun 12, 2009 | 12:11 AM
KatsCam's Avatar
Car: 1991 Camaro RS Coupe
Engine: 5.0-liter (305) TBI V8
Transmission: 700R4-speed automatic overdrive
Axle/Gears: stock/2.73
Re: Oxygen Sensors
They regulate your fuel and air mixture, which should be 14:7.1. I just changed mine, the front one by the exhaust manifold. The check engine light will come on if it's really bad. (You can check the code with a paper clip to flash the light, if it is on.) But it can be going bad long before the light comes on. I'm going to add mine to my tuneup schedule now.
My car has better response, more power and is getting better gas mileage with a new one. Go Delco for the replacement. Pricier, but what the car needs and should get, IMO.
I read a lot before changing it. Google replacing oxygen sensor.
Old Jun 12, 2009 | 03:30 AM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
Re: Oxygen Sensors
It senses how much unburned oxygen there is in the exhaust. It can tell by how much oxygen is left whether or not you're running rich or lean. For all of your fuel to burn, it must have oxygen in the correct (stoichiometric) amounts. As mentioned, 14.7:1 is what the aim is.
The computer reads how much oxygen is unburnt in the exhaust via the sensor and adjusts how much fuel it's putting into the car accordingly.
If your oxygen sensor is bad it will give incorrect readings and the comptuer will dump incorrect amounts of fuel into the motor. This can result in minor issues usually, since there's so many other sensors the computer is using to meter air and fuel at the same time, but it wont run its best, and if it gets really bad it can cause all sorts of problems. The car will just run like it's not tuned properly.
Old Jun 29, 2009 | 03:30 PM
MY87LT's Avatar
Car: 1987 Camaro LT
Engine: LG4 w/ SLP headers & a 3" catback
Transmission: THM700R4 (Stock)
Axle/Gears: Stock 2.73 gears. No Posi
Re: Oxygen Sensors
Now I am going to butt in and say Walker Oxygen Sensors are better than the stock AC/Bosch.
HoosierinWA
Oct 7, 2015 10:15 AM
aaron7
Sep 30, 2015 09:15 AM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
dusterbd
Sep 29, 2015 08:40 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
