Replacing exhaust, ideas?
Old Jun 16, 2009 | 10:55 PM
Transam.82's Avatar
Car: '82 Trans Am
Engine: 388 5.7L V8
Transmission: T-10
The exhaust in my '82 t/a is rusting out, and I need to replace it. can I do that with the exhaust parts I see at autozone or o'reilly? I'm on a budget and live with my parents(college student) so I have to keep it quite. Though I don't want to lose too much performance. Also any muffler ideas? Right now I (parentmade) a SSR muffler on the t/a and neighbors and parents complain, though I like it
Old Jun 16, 2009 | 11:05 PM
tony_cogliandro's Avatar
Car: 1990
Axle/Gears: stock
Re: Replacing exhaust, ideas?
hooker 2055 headers with y-pipe. new 3 inch internal hi flow cat, then a 31 inch by 3 inch internal chambered exhaust.
cat less than 100.00
chambered exhaust - uses it as the center pipe - 80.00
headers - about 150.00 if you look around.
Old Jun 16, 2009 | 11:14 PM
Transam.82's Avatar
Car: '82 Trans Am
Engine: 388 5.7L V8
Transmission: T-10
internal chambered exhaust? whats that? And if I'm on summit how can I tell if the catalytic converter is hi flow?
Old Jun 17, 2009 | 09:33 AM
matj1990's Avatar
Car: 83 firebird/camaro conversion
Engine: carbed 350 very mild build
Transmission: th350
Axle/Gears: 3.42 posi
most aftermarket cats are hi flow
Old Jun 17, 2009 | 01:43 PM
Transam.82's Avatar
Car: '82 Trans Am
Engine: 388 5.7L V8
Transmission: T-10
I was checking chambered exhaust online, and most people said it restricted the performance, and say X-pipes were quieter and less restrictive on hp. I don't enough about this to really know whats what or how it works....
Old Jun 17, 2009 | 02:03 PM
matj1990's Avatar
Transmission: th350
x pipes for for people who want to run tru dual exhaust it joins the 2 pipes together and then goes back to duals to keep the flow on each pipe and the sound correct a chambered muffler will most likely be more restrictive then a flow through example glasspack vs flowmaster 40 but with your 305 i realy dont think i would worry about it if u need a cheap fix go to ebay search for exhaust camaro and pick your year you will be able to find a muffler in without the i pipe for about 100 bucks made by dynomax it will sound pretty close to stock so its not that loud but has a nice rumble when u get on it
Old Jun 30, 2009 | 12:26 PM
Transam.82's Avatar
Car: '82 Trans Am
Engine: 388 5.7L V8
Transmission: T-10
Ok, if I replace the exhaust now will that have to be changed if I put in the 350 sbc I'm rebuilding stroked? And what would dual exhaust do for me?
Vintageracer
Jan 10, 2020 05:33 PM
transaero
Aug 31, 2015 01:14 AM
TheExaminer
Aug 26, 2015 04:59 PM
db057
Aug 22, 2015 08:17 PM
drathaar907
Aug 6, 2015 04:20 PM
