Fixing/replacing my exhaust
Old Jun 27, 2009 | 11:35 PM
p100ki's Avatar
Here's what i plan on buying since my exhaust is toast and i want to remove the a.i.r. system.
I'm going to buy these parts from Summit.
Hedman Hedders 68460 - Hedman Street Hedders
2 of these
Flowmaster 943047 - Flowmaster Super 44 Series Mufflers
Flowtech 53631FLT - FlowTech Universal Cross Pipes with Cut Outs
2 of these
Gibson Performance 500384 - Gibson Stainless Steel Exhaust Tips
I like the sound of the super 44s and they are super small.
Case Length (in)
13.000 in.Overall Length (in)
19.000 in.Thickness (in)
4.000 in.Width (in)
9.750 in.
I'm going with 3" all the way to the rear bumper, i want it to appear stock from the rear. Do you think it will work?
Old Jun 28, 2009 | 12:52 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: Fixing/replacing my exhaust
none of that will bolt together, or even line up for that matter, there are no overaxle pipes, and you woll loose a lot of ground clearance. If you want duals, there is a sticky on that topic, but you will not be able to use that x-setup, there is just no room
Old Jun 28, 2009 | 02:15 PM
p100ki's Avatar
We just put that x pipe on an 88 Iroc with quick clamps, and cut down to size. The same shop is doing my car an they are custom bending all of the other pipes. I'm not completely sold on the x pipe yet but I'll nost likely pick everything else up.
zapr
Jul 27, 2018 06:03 PM
PurelyPMD
May 5, 2016 04:57 PM
86White_T/A305
Mar 6, 2016 01:48 PM
1992Z28!
Nov 19, 2015 07:33 AM
david068513
Sep 18, 2015 10:36 AM
