Question on installing SLP Longtubes.
Old Jul 25, 2009 | 05:11 PM
chevman24's Avatar
Car: 88 and 02 Camaro's
Engine: L96 (LS) and LS-1
Transmission: auto, 6 speed
Axle/Gears: 3.42 gears for both
I know this is a third gen site but im sure someone in here has to have a fourth gen.
Im installing SLP longtubes on my 02 Z. The headers are already installed and the y-pipe and everything is loosely connected. No matter what i do i cannot get the new catback exhaust to line up correctly. The angle of the end of the y-pipe is so severe that i cant connect them. Shouldnt the ypipe come straight out to connect to the new system?
im at wits end with this. The project should be done.
Old Jul 25, 2009 | 09:49 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: Question on installing SLP Longtubes.
what y-pipe? if its not SLP's, made for your headers, you shouldnt assume it will work.
all else fails, take it to a good muffler shop and have the fix it.
Old Jul 26, 2009 | 08:11 AM
chevman24's Avatar
It is the SLP y-pipe. Im going to call them tommarro. Cause the ony way i can connect my cat-back system is without the exhaust crossmember connected.
I dont want to have the ypipe modified cause i dont want to ruin the warranty.
Old Jul 26, 2009 | 06:40 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
well it seems that its an issue with the product, so i would see what slp says.
Old Aug 3, 2009 | 02:05 PM
BigWhiteGTP's Avatar
Car: 1994 Trans Am
Eff the warranty on the Y-pipe and have a shop modify it.
Old Aug 3, 2009 | 02:12 PM
chevman24's Avatar
Already sent it back to SLP. I spent enough on the system that everything should mount up without paying more money to a local shop to fix the issue!!!!!!!!!!
Talked to SLP and they siad the ypipe wouldnt fit their Jig, and they dont know how it happened. They are shipping me a new one.
Old Aug 7, 2009 | 12:18 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
If you need help with 4th gen info, you can go to camaroz28.com or ls1tech.com . This website is for discussing thirdgen vehicles and thirdgen engines.
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
fonzie85
Exterior Parts for Sale
39
Mar 16, 2016 07:07 AM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
redmaroz
Aug 16, 2015 11:40 PM
