Backfire
Old Jul 27, 2009 | 03:55 AM
Scratchys89RS's Avatar
Car: Red 1989 Camaro RS
Engine: Stock 305 ci TBI
Transmission: 5 Speed manual
Backfire
it there any way to stop the backfiring on my rs? i think its blown up like two mufflers, and i dont wanna replace it if its just gonna get blown out again.
it backfires when i let off the gas at pretty much any rpm (but louder with higher rpms)
Old Jul 27, 2009 | 08:34 AM
New2Chevy's Avatar
Car: 1995 Formula
Engine: LT1 350
Transmission: Built 4L60e
Axle/Gears: 10 bolt, Eaton posi, 3.73's
Re: Backfire
Do the easy fix first and check your ignition timing. If your ignition timing is good, then check your cam timing. I'd start there.
Old Jul 27, 2009 | 04:21 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: Backfire
yes - the exhaust is the symptom - you need to fix the cause, which is a tuning issue of some kind. Check the basics, ignition, timing, fuel, spark, a/f ratio, etc.
Old Jul 27, 2009 | 06:21 PM
87_TA's Avatar
Re: Backfire
You need 3 things for a backfire, heat, fuel, oxygen - You are getting excess fuel, but you need air to ignite that fuel, leaking exhaust system will cause the ignition.. Or maybe you do not run a tailpipe?
tyeo098
Nov 30, 2015 06:27 PM
racereese
Oct 3, 2015 03:46 PM
85 Jimmy
Sep 30, 2015 07:56 AM
RedLeader289
Sep 23, 2015 06:50 AM
Racerx974
Sep 19, 2015 10:16 AM
