exhaust install problem
Old Jul 29, 2009 | 10:32 PM
brocknstock's Avatar
Car: 91 Camaro Z28
I'm installing a stock exhaust in my 91 convertible, I have the car on stands and have removed the old exhaust. what is the easiest way to get the pipe over the rear axle? Do i have to have it on a lift? Does anyone have a easy way for me to do it with it just on stands. Thanks
Old Jul 29, 2009 | 11:13 PM
PURPLEFORMULA's Avatar
Car: '89 Formula Firebird
Engine: LSX-451 / 705HP
Axle/Gears: Moser Ford 9" with 4.30
Re: exhaust install problem
It will be tight, but try putting the jack stands on the sub-frame and let the axle hang. If that still doesn't give you enough room, than unbolt the shocks and the axle will drop even farther, but when you go to put the axle back up make sure the springs are seated right.
Eric
Old Jul 30, 2009 | 01:17 AM
V6F1R3BRD's Avatar
Car: 1988 Firebird - 1998 Z28
Engine: 2.8 - LS1
When i did mine i used my bud's garage. He has one of those oil changing pits so i had plenty of room to hook it around.
Vintageracer
Jan 10, 2020 05:33 PM
db057
Aug 22, 2015 08:17 PM
gta power
Aug 13, 2015 06:15 AM
drathaar907
Aug 6, 2015 04:20 PM
