Hooker 2451K
Old Aug 21, 2009 | 10:03 PM
nevertheless's Avatar
Hooker 2451K
i was gonna get this for my 82 camaro with the stock 305. i need something cheap and good (if such a thing exists!) is this a good choice?
Old Aug 23, 2009 | 06:37 PM
kkingsrulee's Avatar
Car: 1990 Camaro RS
Engine: V8 305 TBI
Transmission: W/C T5
Axle/Gears: 3.08
Re: Hooker 2451K
Go with shorty headers, you'll have a hell of a time getting those long tubes in and clearance is a big issue with long tubes.
Go with these
http://www.jegs.com/i/Hooker/520/2055/10002/-1
Old Aug 24, 2009 | 10:49 AM
Re: Hooker 2451K
ok thanks! does the rest of that package look ok?
Old Aug 24, 2009 | 06:20 PM
Car: 1990 Camaro RS
Engine: V8 305 TBI
Axle/Gears: 3.08
Re: Hooker 2451K
Well this is a true dual exhaust set up which will require two catalytic converters which this kit doesn't provide. Plus it's reduced to a final pipe diameter of 2 1/2, which will inhibit power if you ever choose to upgrade to a 350 or an engine of a higher displacement.
A good rule to go by if you've got a 305 and want to upgrade in the future is to choose an exhaust system that can be swapped over with either no modifications or minor ones. This is obviously done to save money in the long run.
So you'll generally want to look for 3 inches in diameter for piping. Of course this can be argued through backpressure and exhaust theory, but that's another story all together which would require something more than "cheap".
You'll probably want to look into a different muffler also, go with a hooker max flow http://www.jegs.com/i/Hooker/520/21606/10002/-1
or aerochamber http://www.jegs.com/i/Hooker/520/21505/10002/-1
both boast very good CFM flow numbers compared to straight-pipes and other aftermarket mufflers.
Hope this helps.
Old Aug 24, 2009 | 11:56 PM
Re: Hooker 2451K
that definitely helps man! thanks alot! all these muscle car brands are new to me, and i didnt really know where to look
no green
Jan 9, 2016 09:22 PM
thekurlyone
Sep 30, 2015 12:54 PM
Chevykid810
Sep 28, 2015 12:57 PM
ssgt usaf
Sep 21, 2015 12:45 PM
Tylermcclinton
Sep 17, 2015 07:50 PM
