Horsepower gain going from 2.5" to 3" exhaust?
Old Nov 3, 2009 | 04:25 PM
tater's Avatar
Car: Dad's 87 Bird (Org Owner)
Engine: Vortec 350 Crate Motor
Transmission: TH350
Axle/Gears: 3.42 Posi
This is on a mild 350.
Just trying to justify the cost. I already have the 2.5".
Old Nov 3, 2009 | 05:14 PM
Guest
Guest
Posts: n/a
Re: Horsepower gain going from 2.5" to 3" exhaust?
Assuming your exhaust had no bends, cat or muffler, at the 270 crankshaft HP level is where the 2.5" begins making measurable backpressure.
Old Nov 3, 2009 | 06:35 PM
91RSinNS's Avatar
Car: 1991 Camaro RS Convertible
Engine: 305 V8 TBI
Axle/Gears: 4.1
A pipe will flow 115cfm per square inch of cross-sectional area. You need roughly 2.25cfm of flow per crank horsepower.
A 2.5" Pipe is 4.9 square inches of theoretical surface area. That means that, with no restrictions, etc, you could be generating 250 horses before the 2.5" pipe becomes a restriction. A 3" Pipe is 7.05 square inches, giving you the ability to flow ~365 horses before it becomes a problem. Keep in mind, this is assuming no restrictions.
Old Nov 3, 2009 | 07:04 PM
tater's Avatar
Transmission: TH350
Well I measured my exhaust and it is 2.25. Yuk! It was my dad's 2.8 '87 Bird.
Since I need new exhaust I'm going with 3". I'll be installing a vortec 350 with a ZZ4 cam and a carb. I'll be making more than 270 hp.
Thanks for the info!
Old Nov 4, 2009 | 06:08 PM
paul_huryk's Avatar
Car: 1984 LG4 Camaro
Engine: 350 Roller Motor
Transmission: Level 10 700R4
Axle/Gears: Strange 12 bolt 3.42
Stock 2.25" pipe is good for 175hp before becoming a restriction on a V8.
I picked up 35hp by going from stock LG4 exhaust to a banks y-pipe, 3" cat, and banks cat back way back in 1990 without any additional tuning.
Old Nov 6, 2009 | 05:09 PM
DrewsCam's Avatar
Car: 1991 Z28
Engine: 355 TPI
Axle/Gears: 9 bolt disc / 3:27
I was looking at the same thing for mine but i already started buying up parts for a 2.5... I'll be posting them up for sale and starting over
zapr
Jul 27, 2018 06:03 PM
PurelyPMD
May 5, 2016 04:57 PM
dbrochard
Sep 25, 2015 04:56 PM
david068513
Sep 18, 2015 10:36 AM
IROCThe5.7L
Sep 17, 2015 07:48 AM
