Correct Choice for 85
Old Nov 21, 2009 | 11:36 PM
terl30's Avatar
Car: 1990 Iroc,02 ws6,74 corvette
removed the 305 installed carbed 350 i was thinking about going with Dynomax 89009 header back kit. but am unsure what headers to use the stock manifolds bolt holes are about 1/3 inch longer on the passenger side rear so i know if i ordered a set of shorty headers for an 85 id have same problem so what im asking is what headers do i need to get....???
Old Nov 24, 2009 | 04:43 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
If you get all your exhaust for '86-'90 TPI single cat application - headers, cat, cat-back - you'll be getting the "good stuff". No issues with routing, as it wasn't the chassis that changed over the years. You might need to modify a hanger or two.
IMO, the 89009 is not the "right stuff". Note the instructions say, "THIS KIT WAS DESIGNED FOR DYNOMAX HEADER #85012. IF THE KIT IS BEING INSTALLED WITH HEADERS OTHER THAN LISTED ABOVE, MODIFICATION WILL BE REQUIRED." Those headers are 1-1/2" primaries - good for a 305, or for a low-RPM 350. The kit doesn't include mufflers, and is relatively small crimp-bend tubing.
A simple 3" mandrel bend cat-back would flow better, route easier, and by the time you get it installed, cost less.
FormulasOnly
Jul 23, 2018 08:47 AM
Fronzizzle
Feb 9, 2017 09:31 AM
gmoutdoorsman
Oct 3, 2015 11:42 PM
ericjon262
Sep 11, 2015 06:07 PM
scottmoyer
Sep 7, 2015 07:06 PM
