Question on Emmission Regulations
Car: 1984 Camaro
Engine: 5.7L V8 (350)
Transmission: TH350
Axle/Gears: stock
I can't remember what year your car had to be older than to not have to have a catalytic converter installed on your car. (in North Carolina). I have an 84, i think it qualifies, but not sure.
Car: 1987 Camaro Sport Coupe
Engine: None
Re: Question on Emmission Regulations
It's illegal to run a vehicle that came with a catalytic converter without one.
However apparently only cars from 1996 and newer require emissions testing over there but a catalytic converter is still required by federal law.
Car: 1984 Camaro
Transmission: TH350
Axle/Gears: stock
then i don't have to have one. it came with one, but since t is older, i can take it off, as long as it passes inspection
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
The likelyhood of you ever having an issue without one is slim, but run into roadside inspector having a bad day and you can say goodbye to the car and possibly a fine.
Car: 1992 Camaro RS
Engine: 305 TBI
It doesn't matter in NC what year the car is unless it older than 35 years. IF it came with a CC you must have it and all smog equipment. Only cars from 1996 and newer have to undergo the OBII testing.
Car: 85 trans am
Engine: 5.7 goodwrench edelbrock everything
Transmission: t-5 stage 2 clutch
Axle/Gears: 3.27 posi
here in nc the car is required to have a cat ,egr valve ,pcv and a smog pump
