Safety Inspection help - Ontario
Old Jan 4, 2010 | 03:29 AM
marekdennhardt's Avatar
Car: 1985 Camaro
Engine: 2.8l
Axle/Gears: Stock
Hey I bought my car and the catalytic converter was already removed and replaced with pipe. I am wondering if it will pass safety without it or will I need to get one.
Old Jan 4, 2010 | 03:39 AM
ShMaCk2004's Avatar
Car: 1987 Camaro IROC-Z
Transmission: LS1 T56
Axle/Gears: Richmond 3.73
Re: Safety Inspection help - Ontario
not here in VA.
Old Jan 4, 2010 | 04:16 AM
Car: 1985 Camaro
Engine: 2.8l
Axle/Gears: Stock
Good sign. Does anyone know for sure. In north western ontario
Old Jan 4, 2010 | 04:18 AM
89transam*pearl's Avatar
Car: 89 T/A
Engine: LB9
Transmission: W/C T-5
Axle/Gears: 10 bolt posi, 3.73 Richmond Gears
In NS anything built before 1990 doesn't reqire a cat to pass inspection...not sure about Ont regs. I removed my cats but replaced the next year due to the smell!
Old Jan 4, 2010 | 04:54 AM
Car: 1985 Camaro
Engine: 2.8l
Axle/Gears: Stock
I hope it's like that here. That would just be another days work getting that rusty crap to fit. Not to mention I would have to get a cat. If I had to get one I would just grab one off an old parts car and get rid of the cat all together when I decide its time for a 350
Old Jan 4, 2010 | 06:21 AM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
Any car in the US or Canada that required a Catalytic Converter will FAIL a Emission Test without one. Don't even waste your time & money even trying without one.
Old Jan 4, 2010 | 06:30 AM
Car: 1985 Camaro
Engine: 2.8l
Axle/Gears: Stock
There are no emissions tests where I live, so im clear on that.
Old Jan 5, 2010 | 08:43 AM
The Project's Avatar
Car: 89 IROC
Engine: 305 TPI / ZZ4 cam
Transmission: Stage 2 700R4, LS1 driveshaft
Axle/Gears: Strange 3.42 w/ Auburn
In Ontario, you need to have ALL the pollution equipment that the car came with originally.....so...you should put the cats back.
If you get pulled over by the MTO (for inspection) they will pull your plates and fine you.
I'd sugest some magnaflow cats. They flow very well.
Old Jan 5, 2010 | 04:02 PM
Car: 1985 Camaro
Engine: 2.8l
Axle/Gears: Stock
Thanks for the advice. Now I need a cat. I'll look into a magna flow.. or ill just take one off a junker car.
Lbibb
May 5, 2016 12:00 AM
skinny z
Oct 5, 2015 06:23 PM
bjpotter
Oct 4, 2015 07:48 PM
Buickstaged
Interior Parts Wanted
Oct 4, 2015 11:49 AM
PeteK825
Sep 22, 2015 10:47 AM
