Hedman Longtubes on a 350 T5?
Car: 1991 Camaro RS/1989 Vert RS
Engine: 355/350
Transmission: T-5/T-5
Axle/Gears: BW9bolt3.45posi/3.23 Posi
Alright so I am debating on whether or not I should get these headers. I have always liked the idea/sound of longtube headers.
Now I am converting my 91 350 RS camaro to a T-5 next weekend more than likely. I understand there are problems with these headers and T-5 transmissions.
I was wondering if this was the solution to my problem:
http://www.jegs.com/i/Hedman/500/18804/10002/-1
So I just cut the collector on the headers and weld that bend on and be good?I only need to do the drivers side correct?
Than when I do that, I would like tto run 3 inch exhaust. True duals would be sweet but I am worried about ground clearance.
Better yet is it possible to just hook it straight up to my 3" american thunder exhaust using a Y-pipe? I don't need a cat anyway as they don't check it in inspections where I am at.
Thanks for any help in advance.
Car: 1988 Formula
Engine: 388ci
Transmission: WC T-5: t56 in the makes
Axle/Gears: 4th gen rear 3.42
Re: Hedman Longtubes on a 350 T5?
i dont know if you can get away with cutting off the end or not, i know long tubes wouldnt fit on mine with the T-5, i tried. i went with the shorties and there isnt much clearence with them either, good luck
I used them for years with a T-5 and had no issues. When I installed them there was a little interference with the slave cyl bracket. I bent the drivers collector down a little and had no problems for the 3 years or so I ran them.
Car: 1988 Formula
Engine: 388ci
thats sweet man, glad yours worked, but i bought a set of cheepo long tubes that would fit an automatic 88 305 and couldnt squeeze them in, tried for two days and then returned them for the shorties, but maybe i just wasnt holding my tounge right, wish it woulda worked but oh well
Car: 1985 IROC-Z Silver
Engine: Vortec 5.7L
Transmission: WC-T5
Axle/Gears: 3.23 disc brake 10 bolt
Im in the process of doing this....As soon as it warms up here. With the ball and socket flange it is a pain in the **** now... this puts the flange right even with the slave cylinder and it blows...I tried cutting it off, extending a few inches then denting it.... Would work but I didnt like it since I want every last HP out of my car. I am gonna have the quickest vortec headed car this board and others have ever seen this summer, so I am extending all 4 primary tubes to let the collector hang low enough... I may even this to Doug's 1-3/4" cuz I dont know if these are gonna cut it..
Billy Decker
Sep 4, 2015 03:46 PM
