Anyone have Long tubes / 700r4 and a aftermartket crossmember?
Old Feb 15, 2010 | 12:39 PM
FueledSoul's Avatar
Car: 84 camaro, 88 trans am, 98 camaro
Engine: Modded , stock, LSX modded
Transmission: 700r4, 700r4, t-56
Axle/Gears: 327, 308, 373
I would like to see pics of peoples y-pipes that are running long tues a 700r4 and aftermarket cross members
Old Feb 20, 2010 | 10:32 AM
FueledSoul's Avatar
Re: Anyone have Long tubes / 700r4 and a aftermartket crossmember?
bump
Old Feb 20, 2010 | 10:46 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
I've got 68460s and a Spohn crossmember, probably one of the more difficult combinations for routing exhaust. No pictures of it installed, though.
Old Feb 20, 2010 | 10:54 AM
toxik IROC's Avatar
Car: 1987 Camaro
Engine: 350 hsr
Transmission: 700R4(blown)
Axle/Gears: 3:73
i had the umi crossmember and with the longtunes it would have beeen waay too low for ground clearance so i went back to the stock crossmemeber and notched that abit ill
Old Feb 20, 2010 | 04:14 PM
FueledSoul's Avatar
Id be interested to see it before you swap back to the stock peace, im running a UMI tranny cross member, long tubes and im lowered
Old Feb 24, 2010 | 07:47 PM
CRAMOS78's Avatar
Car: 92 camaro
Engine: stroker
Transmission: Megaraptor
i have stainless works long tubes, 700 r4 and a spohn x member.
i just finished fabing up a y pipe here some pics
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
the old set up....
[IMG][/IMG]
[IMG][/IMG]
i need to take it to the muffler shop so they can finish welding the joints as i just tacked it together. its 2.5 mandrel bent, should flow a hell of a lot better and be a tad better tucked up than the old one.
Old Feb 24, 2010 | 08:36 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Love the dremel in the first pic... how many cutoff wheels did you go through on each joint?
Old Feb 24, 2010 | 08:43 PM
CRAMOS78's Avatar
Car: 92 camaro
Engine: stroker
LOL, only one, i used it to cut off the tacks when i screwed up
those dremels are pretty handy, took of the original hinges with those.
THERE I WENT THROUGH 2 1/2 LOL
Old Mar 17, 2010 | 11:02 PM
FueledSoul's Avatar
Think... buying 2 or 3 J bends would be adequate for the bends for a y-pipe? what have people used or order to make theirs?
Old Mar 18, 2010 | 12:21 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
I used 3 U bends to build mine, but that was to get over the axle, too.
Old Jun 4, 2010 | 05:17 PM
FueledSoul's Avatar
anyone have any more pics?
Old Jun 4, 2010 | 05:55 PM
skinny z's Avatar
Stainless Y-pipe made from 2 Vibrant J-Y bends (2 1/2").
Modified cross member.
Attached Thumbnails Anyone have Long tubes / 700r4 and a aftermartket crossmember?-1.jpg   Anyone have Long tubes / 700r4 and a aftermartket crossmember?-1.1.jpg   Anyone have Long tubes / 700r4 and a aftermartket crossmember?-1.4.jpg
Old Oct 28, 2010 | 11:41 AM
FueledSoul's Avatar
Wow that looks super nice!
Old Oct 28, 2010 | 04:13 PM
skinny z's Avatar
Funny you should comment. I just removed the entire exhaust with headers and crossmember and am swapping it into another 3rd gen.
With any luck I'll have it done tonight.
Old Oct 28, 2010 | 09:40 PM
Dustytrix's Avatar
Car: 1990 Iroc
Engine: 6.0
Transmission: 4l65E
Axle/Gears: 373 zexel torsen
That is one of the best looking exhaust jobs I have seen. Did you have any pictures after the Y ?
Old Oct 28, 2010 | 10:10 PM
skinny z's Avatar
It's just a Flowmaster 3" cat back (minus the cat) with a single 30 series muffler in the stock location. I just grafted on a header flange and bolted it to another flange welded to the y-pipe (more or less).
Old Jan 9, 2011 | 10:44 PM
FueledSoul's Avatar
Do you have any pics of it on the car now? maybe some ground clearance shots again it looks great!
Old Jan 11, 2011 | 09:57 AM
skinny z's Avatar
Here are pics when it was installed on the old chassis (Damn. That thing is dirty!)
Attached Thumbnails Anyone have Long tubes / 700r4 and a aftermartket crossmember?-.jpg   Anyone have Long tubes / 700r4 and a aftermartket crossmember?-b.jpg   Anyone have Long tubes / 700r4 and a aftermartket crossmember?-c.jpg
Old Jan 11, 2011 | 10:00 AM
skinny z's Avatar
A few ground clearence shots. This was with an 1.5" drop spring and about 30 000 miles on them as well.
Attached Thumbnails Anyone have Long tubes / 700r4 and a aftermartket crossmember?-d.jpg   Anyone have Long tubes / 700r4 and a aftermartket crossmember?-e.jpg   Anyone have Long tubes / 700r4 and a aftermartket crossmember?-f.jpg
Old Jan 11, 2011 | 10:11 AM
skinny z's Avatar
A couple more on the new chassis.
Attached Thumbnails Anyone have Long tubes / 700r4 and a aftermartket crossmember?-g.jpg   Anyone have Long tubes / 700r4 and a aftermartket crossmember?-h.jpg
Old Jan 11, 2011 | 12:34 PM
1986chevycamaro's Avatar
Car: 92camaro,86 camaro
Engine: 355
probably not what you want but here is what i got long tube with true duals. sorry for crappy cell pics
Attached Thumbnails Anyone have Long tubes / 700r4 and a aftermartket crossmember?-exhuast.jpg   Anyone have Long tubes / 700r4 and a aftermartket crossmember?-exhuast2.jpg
Old Feb 21, 2011 | 07:32 PM
FueledSoul's Avatar
Got the part# for the claps that connect the tubing off the headers to the magnaflow y-pipe?
those are lap joint style right? is that y-pipe made to slip fit the tubes inside it?
Old Feb 21, 2011 | 07:46 PM
skinny z's Avatar
Off hand, no.
The pair in the picture are from the local tractor trailer repair shop. I asked for a stepped band clamp for 2 1/2" pipe. If you're stuck and can't find what you're after, I can check with the shop for a part number.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
TheTraut88
Sep 7, 2015 05:22 PM
buckshot63
Interior Parts Wanted
Sep 3, 2015 08:10 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
