Header to Y-Pipe Gasket info needed
Old Mar 2, 2010 | 04:31 PM
jbradhill's Avatar
Car: 1986 Camaro IROC Z28
Engine: 383 SBC
Axle/Gears: 3.75 LS
I just purchased a set of SLP shorty headers to 3" along with 3" Y-Pipe. I need some kind of gasket, but not sure what. I attached a pic. It looks like it needs some kind of 'donut' gasket, but not sure where to find. ... maybe I go to an exhaust shop? Auto parts stores always find everything by make and model... which won't work out here
Any ideas? thanks! Brad
Old Mar 2, 2010 | 05:54 PM
AmorgetRS's Avatar
Re: Header to Y-Pipe Gasket info needed
I went to the local Schucks and let they me dig throught their exhaust donut bin until I found something that worked. I wish I had the p/n for you, but someone I am sure does.
Old Mar 2, 2010 | 06:25 PM
jbradhill's Avatar
Engine: 383 SBC
Axle/Gears: 3.75 LS
... all I need to look for is a donut that will slide over a 3" pipe? What are they made of? Are they soft enough that they just conform to the mating surface by tightening down so that it is not real important on the donut thickness and OD?
Old Mar 2, 2010 | 06:52 PM
Drew's Avatar
They're just an exhaust donut. Fel pro and Walker both make them. Your best bet is to measure the inside diameter and just dig through the box at the parts store til you find one that matches.
1992 Trans Am
May 10, 2023 07:19 PM
IROCZ1989
Jan 24, 2016 03:55 PM
NinjaNife
Aug 23, 2015 11:49 AM
86camaroman201
Fabrication
Aug 11, 2015 10:39 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
