Building my own true duals
Old Sep 2, 2010 | 06:54 PM
  #51
pwdbychevy's Avatar
Car: 1991 Camaro Z28
Engine: Dart SHP 406ci T88 turbo
Axle/Gears: QP 35 spline Ford 9" 3.50 gears
Re: Building my own true duals
Ok guys here's a video of the sound from the new magnaflows with dual tips.
Old Sep 2, 2010 | 07:07 PM
  #52
Shadow Z's Avatar
Car: Lots of 'em
I have to admit, that is one of the best sounding third gens I have ever heard.
Old Sep 2, 2010 | 07:25 PM
  #53
pwdbychevy's Avatar
Thanks. For those who don't know, the whiny noise is the Pete Jackson "quiet" gear drive.
Old Sep 3, 2010 | 02:01 PM
  #54
quick87formula's Avatar
Car: 87 formula
Transmission: 700
Axle/Gears: 12 bolt strange 3.73
looks and sounds great. love the gear drive. i was thinking of getting one.
Old Sep 3, 2010 | 11:20 PM
  #55
joepackersrock's Avatar
Car: 1991 RS Camaro
Engine: 400 Smallblock
One MEAN v6 you got there
Old Sep 4, 2010 | 08:09 AM
  #56
pwdbychevy's Avatar
Yeah it's a one-of-kind
Old Sep 5, 2010 | 11:46 PM
  #57
mario 91-87's Avatar
Car: 91 and 87 camaro
Engine: 91 360ci and 87 350ci
Transmission: lt1 t56 ,wc t5
Axle/Gears: 3.23 2.42
o man what sizes is that v6 that sounds so mean i want one like it lol
Old Sep 7, 2010 | 08:28 PM
  #58
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
Axle/Gears: 3.45 9 Bolt
That is how I was thinking about doing duals in my car. Did you have to modify the frame rail in the front at all where they come around in the 3rd picture?
Old Sep 7, 2010 | 08:39 PM
  #59
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
there is quite a lot of room in that spot though, and some y-pipe setups, SLP, dons, edelbrock i think, use 2 pipes there already. you should know that
the slp's on my car have the dual pipes at that point, they are only 2.25, but with a better design, there is more than enough room fot fit larger pipes there.
Old Sep 7, 2010 | 08:40 PM
  #60
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
Old Sep 7, 2010 | 08:51 PM
  #61
//<86TA>\\'s Avatar
Car: 86 Trans Am
Old Sep 7, 2010 | 08:55 PM
  #62
pwdbychevy's Avatar
No I didn't have to modify it.
Old Sep 15, 2010 | 01:45 PM
  #63
Sutoto2189's Avatar
Car: '85 Iroc-Z, '03 Z71
Engine: Blown 383, 323 SBC
Transmission: 700r4, 4L60E
Axle/Gears: GU6 3.42, G80 3.73
And that ladies and gents... THATS WHAT IM TALKIN' BOUT!! Sounds very nice if you ask me. Thats exactly how i want my car to be set up when i get all done with her. Dunno if it will work seeing how im going to have to run 3" duals. 383 with a 177 street blower.. Actualy blew out the exhaust manifold gasket between the header and the heads a few times. Just cant get the exhaust out fast enough..
Old Sep 15, 2010 | 03:23 PM
  #64
stealth908's Avatar
Car: 87 GTA
Engine: tpi 350
I have a few questions for you. Did you bend your own pipe? Also, what did you use to hang everything?
Old Sep 15, 2010 | 09:53 PM
  #65
pwdbychevy's Avatar
I used 2.5" mandrel bends I bought on ebay. I cut off the factory hangers and welded them on the new exhaust. The hanger by the the tranny I custom made.
Old Sep 16, 2010 | 02:06 PM
  #66
stealth908's Avatar
Car: 87 GTA
Engine: tpi 350
About how much do you think everything cost, without the mufflers? I have a new Hobart and I'd like to build my own exhaust system, but only if it's cost effective against a prefabbed single pipe cat back system. Flowmaster sells a cat back for $289.
Old Sep 16, 2010 | 06:43 PM
  #67
HF_monster's Avatar
Car: 86' z28 (died 5/1/11) 76 k10 pickup
Transmission: th350
Axle/Gears: 3.73 open
what subframe connectors were those? Im looking to do about the same to mine when I have the money nice job.
Old Sep 16, 2010 | 07:09 PM
  #68
pwdbychevy's Avatar
I built the entire system including mufflers for less than $300. The subframe connectors are Chris Alston bolt-ins.
Old Sep 21, 2010 | 02:20 AM
  #69
robguitargod1's Avatar
Car: '91 LS6/T56/9"
Engine: LS6
Axle/Gears: Currie 9"/4.11, detroit truetrac
Could you direct me to the store you bought the pipe from on ebay? Thanks
Old Sep 21, 2010 | 05:08 AM
  #70
pwdbychevy's Avatar
I don't have the listing anymore but I believe the name is tootperformance.
Old Sep 22, 2010 | 02:13 AM
  #71
haroanarchist's Avatar
Car: 87 formula
Engine: LG4
PWD is there a wing on top of your hatch?
If there is were would i be able to find one like it?
Old Sep 22, 2010 | 05:08 AM
  #72
pwdbychevy's Avatar
Yes, it's called a Solarwing II made by GTS. They still make them.
Old Mar 21, 2011 | 09:48 AM
  #73
BlackNightRider's Avatar
Car: 87 iroc conti
Engine: 5.7 pro charger
Transmission: 700r
it looks great either way you do it man you are the finally say you are the one that has to like it you are the one that drives it man.
R13_Braz
Sep 18, 2015 05:00 PM
Camaro_383
Sep 11, 2015 11:28 PM
Djmathis123
Sep 8, 2015 08:42 PM
IROCZDAVE (88-L98)
Sep 2, 2015 08:49 AM
IROCZDAVE (88-L98)
Sep 2, 2015 08:43 AM
