What headers?
Old Apr 7, 2010 | 05:20 AM
4playta's Avatar
Car: 1984 Trans Am
Engine: Built chevy 350
Transmission: TCI Built 700r4
Axle/Gears: 3.73 posi 10 bolt
What headers?
I recently picked up a 1984 Z28 for my kid that someone installed a 350TBI motor from a late 80's truck. We are not going put a whole lot of money into it as it runs real good and I just assume leave it alone but I know the manifolds on these motors are a huge bottle neck and one of them has a crack in it. I can get a set of headers for the price on one manifold.
I am going to install some shorty headers from summit the first ones have a Collector diameter of 2.5 inches and 1 1/2 inch primaries the second set I am looking at and will require Y pipe modification has a 3" collector and 1 5/8 inch primaries.
Which of the two would work best for this motor? Would there be any gains using the first set or should I use the second set? I kinda want to use the first set because it has the ball flange and is a direct bolt in with no Y pipe modifications. However if there is much more to be had as far as performance and MPG I will use the second set...remember this is a totally stock motor with no upgrades planned in the future.
Old Apr 7, 2010 | 06:19 AM
3rdgenmaro's Avatar
Car: 88 IROC
Engine: 97 5.7 Vortec LT4 hotcam
Transmission: 700 r4
Re: What headers?
just use the first set. You will not see/feel any gains going with the larger tubes. May even hurt some.
NZKnight
Oct 15, 2015 02:47 PM
redformula88
Oct 14, 2015 06:08 PM
Bradsaundry
Oct 7, 2015 04:35 PM
91 SrS
Oct 7, 2015 04:32 PM
Bigold4x4
Sep 28, 2015 05:21 PM
