exhaust clearence
Old Apr 12, 2010 | 09:07 PM
jfroh1992's Avatar
Car: 91 RS, 93 k1500
Transmission: T5, NV3500
Axle/Gears: stock
exhaust clearence
i want run 3in dual exhaust that will come out right before the back tire. i also want sub frame connectors. im worried that if i have to run exhaust under the connectors i will have no ground clearance. can anyone help me out with a different way to route the exhaust.
Old Apr 12, 2010 | 09:11 PM
1MeanZ's Avatar
Car: 86 IROC
Engine: 383
Transmission: TKO 600
Axle/Gears: 3.54 Dana 44 IRS
Re: exhaust clearence
look at the true dual exhaust thread in the sticky at the top of the page. true dual 3" is very large and not worth the effort unless you need it at your power level. your ground clearance will suffer.
Old Apr 12, 2010 | 09:36 PM
jfroh1992's Avatar
Axle/Gears: stock
i might be getting a 502 thats why i want to do 3in. im not sure if going smaller with that engine would be a good thing or not.
Old Apr 13, 2010 | 02:58 PM
1MeanZ's Avatar
Car: 86 IROC
Engine: 383
Well sizing the exhaust for your power level is your call. True dual 3" on a thirdgen is tricky to do and maintain ground clearance. Check out the true dual sticky thread at the top of the exhaust board and if you still have questions we'll go from there.
Old Apr 13, 2010 | 11:44 PM
jfroh1992's Avatar
Axle/Gears: stock
i checked it out and that answered all the questions i had. i missed out on the 502 anyway so 3 in wont be necessary
zapr
Jul 27, 2018 06:03 PM
PurelyPMD
May 5, 2016 04:57 PM
86White_T/A305
Mar 6, 2016 01:48 PM
1992Z28!
Nov 19, 2015 07:33 AM
david068513
Sep 18, 2015 10:36 AM
