Running catless
Old May 21, 2010 | 10:48 PM
Shane B's Avatar
Car: 92 RS
Engine: 5.slow
Transmission: 5speed
Running catless
I'm thinking of removing the cat on my car but I was wondering what you guys think.Ive got a stock 305 with 169,000 miles on it.Right now its got a hiflow cat with 3in pipe to a flowmaster 80 series.Would I be wasting my time if I take the cat off?
Old May 21, 2010 | 11:34 PM
GeeJenn91RSV8's Avatar
Car: 1991 Camaro RS
Transmission: 700 R4
Re: Running catless
You got a high flow cat... theres no reason to remove it. Leave it on and stay legal.
Old May 21, 2010 | 11:45 PM
Shane B's Avatar
Car: 92 RS
Engine: 5.slow
Re: Running catless
/\Damn you're probably right...better judgement wins again!
Old May 23, 2010 | 11:08 PM
VincentZ28's Avatar
Car: 1990 G92 IROC Z Miniram
Engine: 388cu 6.4 Liters
Transmission: G-Force T5
Axle/Gears: 3.73 Gears
Re: Running catless
It's a felony in California to remove the cats. We have guys here in Southern Cali making from 360whp-403whp with cats and all the smog equipment hooked up. This should change your mind or anyone else about removing the emissions equipment.
Old May 24, 2010 | 06:08 AM
mustangslayer86's Avatar
Car: '88 GTA / '93 Z28
Engine: L98(350) / LT1 (350)
Transmission: 700R4 / 4L60E
Re: Running catless
I had the same engine you have in my 1986 Camaro Z28 and I tried all the options: Stock Cat, Hi-Flow Cat, and No Cat, and I didn't notice much of a difference at all between Hi-Flow and None at all. Leave it on.
Old May 26, 2010 | 04:06 AM
Bungle's Avatar
Car: 1991 Camaro Z/28 Convertible
Engine: LB9 305
Transmission: A4
Axle/Gears: Stock
Re: Running catless
Since my (idiot) PO has both gutted the muffler and replaced the cat with a straight pipe .. that is SMALLER than the stock exhaust diameter ... i'm guessing that this actually hurting performance.
To fix this I have decided to keep the stock headers and Y pipe and go for a Magnaflow cat back, the questions are:
1. which high flo cat?
2. what else will I need to connect all this together?
Thanks in advance
eightsixseven
Dec 16, 2024 01:50 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Fast355
Dec 2, 2016 06:33 PM
perZ
Aug 21, 2015 05:51 PM
ezobens
Aug 19, 2015 10:29 PM
