Removing the Stock Exhaust??
Old Jul 9, 2010 | 12:03 AM
CvilleTransAm's Avatar
Hey guys, I am currently in the process of removing my stock exhaust system on the 88 tranny and replacing it with the dynomax sys. After removing the y-pipe and cat as well as unhitching the muffler, I noticed that the long 3' pipe connecting to the cat/ y-pipe loops over the rear axle and down to the muffler, as one big ol' piece. How would I go about removing this section of the exhaust other than lying on my back and cutting it with a saw for an hour, which Ive almost all but certain have come down to doing. Is there an easier way? All you guys with aftermarket exhausts, how do you go about it?? I really appreciate it, Im not tryna spend a day on my sun-burnt back hacking at this sonnovabitch
Old Jul 9, 2010 | 12:14 AM
JTNKTZ's Avatar
Car: 1991 Camaro RS/1989 Vert RS
Engine: 355/350
Transmission: T-5/T-5
Axle/Gears: BW9bolt3.45posi/3.23 Posi
Re: Removing the Stock Exhaust??
just cut it. Save you headaches. Unless you want to drop the differential.
Old Jul 9, 2010 | 12:24 AM
Stephen's Avatar
Car: 87 GTA
2 choices......
Cut it or.....You can jack the car up as high as possible on STEADY jackstands. Unbolt the tops of the shocks & swing the whole rear own down, then you can pull the exhaust in one piece, from the cat backwards.
That is a very simplified explanation. Beyond that, it is just the details & how-to's.
But if you have already started cutting? Just finish cutting. Pulling it in 1-piece is only in a case for saving it.
Old Jul 9, 2010 | 12:50 AM
elano's Avatar
Car: 86 IROC-Z, 82 z28
Engine: 383 Stroker
Transmission: TH-350
Axle/Gears: 3.73 Torsen, 4.56 Auburn
Stephen covered it. I like to use the sawzall for this. If you don't have one, now would be a great time to invest in one.
Vintageracer
Jan 10, 2020 05:33 PM
TheExaminer
Aug 26, 2015 04:59 PM
gta power
Aug 13, 2015 06:15 AM
3rdgenparts
Aug 8, 2015 07:09 PM
drathaar907
Aug 6, 2015 04:20 PM
