Hitting bottom of car
Old Aug 1, 2010 | 01:33 PM
K-slice's Avatar
Car: 91' Firebird
Engine: 3.1 LH0 V6
Transmission: Auto 700R4
Axle/Gears: 3.23 limited slip
I had the cat replaced with a glasspack for a while and everything was fine. Then when I pulled it out this summer it would rattle under hard acceleration or if i was turning left. It kept getting worse so I had a cat welded on with a new hanger, this only made the problem worse.
As best I can tell the cat is hitting the shield above it despite it having at least an inch of clearance whenever I can check it (car stopped, running, in gear). It's so bad now that even under very lightest acceleration it hits.
Old Aug 1, 2010 | 01:54 PM
92RS_Ttop's Avatar
Car: 1992 Camaro RS
Engine: Rebuilt 350 going in after paint
Transmission: WCT5, 7k & counting behind the 350
Axle/Gears: 4thgen disc rear w/ 3.73 Posi
Re: Hitting bottom of car
How are your motor mounts? If they are shot, its possible for the engine to twist when you give it gas and cause the exhaust to flex up and hit the underside of the car.
Old Aug 1, 2010 | 05:13 PM
19 z28 92's Avatar
Car: 1992 z28
Engine: carb 355
Transmission: wc T-5
Axle/Gears: 4.11 posi 10 bolt
Check the trans-to-crossmember mount, also
Old Aug 1, 2010 | 10:08 PM
K-slice's Avatar
Car: 91' Firebird
Engine: 3.1 LH0 V6
Engine mounts I just had replaced this spring, right around the time this started happening...... I never did inspect their work!
I did check the trans mounts though as i changed the fluid this spring too and thought maybe I didnt tighten something up enough. They all seemed ok, few cracks in the rubber, but no chunks gone or anything.
Old Aug 2, 2010 | 12:57 AM
87350IROC's Avatar
Car: 87' IROC
did you go with poly engine mounts?
BlueIroc-Z
Jun 9, 2019 03:22 AM
theshackle
Mar 5, 2017 06:37 PM
MY87LT
Aug 17, 2015 08:43 AM
kyleb24
Aug 15, 2015 08:24 AM
Amillionoh7
Aug 7, 2015 01:24 PM
