What the last owner did...
Old Aug 4, 2010 | 08:18 AM
Bungle's Avatar
Car: 1991 Camaro Z/28 Convertible
Engine: LB9 305
Transmission: A4
Axle/Gears: Stock
Calling Dr. Magnaflow...
Old Aug 5, 2010 | 07:49 AM
Pocket's Avatar
Car: 91 Trans Am
Re: What the last owner did...
So he put in a test pipe and gutted the muffler. Best budget loud exhaust there is that still retains some exhaust
Old Aug 6, 2010 | 08:52 AM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
that car must definitely make some noise
Old Aug 6, 2010 | 10:17 AM
Carlos773's Avatar
Car: 1986 Pontiac Firebird
Engine: 97 LT1 W/ Alot of goodies.
Transmission: 4L60E W/ Yank SS3600
Axle/Gears: 3.27 9 Bolt BW
I see GM, is that an original muffler? Also its sad the only thing I noticed was the Cat delete and awkward exhaust pipe leading to diff bend. So whats wrong with it? Why not keep it until you can do a full exhaust upgrade.
Old Aug 10, 2010 | 11:16 AM
Bungle's Avatar
Engine: LB9 305
Transmission: A4
Axle/Gears: Stock
yep it's bark is far worse than its bite! and sadly not the only home bodge on the car..
Old Aug 10, 2010 | 02:46 PM
88TransAmGuy's Avatar
Car: 88' White-Black Trans Am
Engine: Trying to find a motor
haha at least your guy actually left the dual tailpipe!
when i got my car,the guy welded like 4 exhausts together and then welded a glasspack to the end=/ and he took off the hanger for the old muffler
So that screwed me over
Old Aug 13, 2010 | 02:20 PM
RedneckNo4's Avatar
Car: Trans am
Engine: 78 350
Axle/Gears: 9 bolt 3.27
and I thought what I found under my TA was bad! does that go to an actual Y pipe or is it just a 90 degree dump?
Lbibb
May 5, 2016 12:00 AM
Briandrex
Oct 5, 2015 06:20 AM
meeklay812
Oct 1, 2015 03:46 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
Aaronv808
Members Firebirds
Sep 30, 2015 12:55 PM
