Question about headers and pully system
Old Aug 7, 2010 | 01:06 PM
Foster382's Avatar
Car: 1991 Formula
Engine: 350TBI
i got a 91 firebird tbi, I'm wanting to get me a set of headers and a y pipe, but i noticed something.
With the cars stock manifolds; the a/c compressor and alternator have a mounting bracked to the manifolds for support.
well the brackets won't bolt to the headers and i dont know what to do with the brackets. won't removing them from the a/c compressor and alternator mess something up or cause my pully system to break?
Old Aug 7, 2010 | 07:03 PM
UNCLE TOM's Avatar
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
Re: Question about headers and pully system
a problem i and many others have had . retain the long bolts that the brackets bolt to . measure the thickness of the manifold you remove , subtract thickness of of header flange . cut a 3/8 i.d. pipe that length and use it as a spacer . a stack of washers will also work . i used a stack of washers at first till i got some S/S pipe cut to length . has worked for me on several cars . good luck .
MustangBeater20
Oct 29, 2022 09:20 PM
theurge
Aug 21, 2015 12:46 PM
redmaroz
Aug 16, 2015 11:40 PM
camaroken83
Aug 10, 2015 11:35 AM
mustangman65_79
Aug 7, 2015 09:55 PM
