HEADER HELP PLEASE !
Old Aug 25, 2010 | 01:27 AM
bocaj25's Avatar
Bought Hedman headers ( long tube) for my 88 camaro (350) after an hour and a half i finaly got the passenger side in but had to pull out the starter and now the header are rubbing on starter, trans cooler lines, lower A-arm mount also the headers dont sit flat on the block... any advise? is there anyway i can get a smaller starter? ( in size)
thank you for any help
Old Aug 25, 2010 | 01:43 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: HEADER HELP PLEASE !
Are they hitting the starter or the K member?
Old Aug 25, 2010 | 01:46 AM
bocaj25's Avatar
when i was trying to squeeze them in it was hitting the k member but got it past that, now it is for sure hitting the starter and the lower A-arm mount
Old Aug 25, 2010 | 01:51 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
It's normal to have to grind the K member for clearance, even if your motor mounts are new.
Do you have a 153 or 168 tooth flywheel?
Old Aug 25, 2010 | 01:56 AM
bocaj25's Avatar
i honestly do not know how could i check ? i just bought this car used bout a month ago tops still learning while trying to upgrade
Old Aug 25, 2010 | 02:00 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Is it 12" across, or 14"? Are the starter bolt holes in a straight line perpendicular to the body of the starter, or staggered?
NZKnight
Oct 15, 2015 02:47 PM
redformula88
Oct 14, 2015 06:08 PM
Bradsaundry
Oct 7, 2015 04:35 PM
91 SrS
Oct 7, 2015 04:32 PM
Bigold4x4
Sep 28, 2015 05:21 PM
