exhaust manifold question/help
Old Sep 17, 2010 | 09:19 PM
mb2hurley's Avatar
Car: 91 camaro rs
Engine: v6 :/
Transmission: auto
i had to replace my oil pump and in doing so had to remove the exhaust and in the process. a bolt snapped in the manifold. so now i have to remove the manifold so i can drill and tap it. i cant get to it while in the car. any suggestions? i really dont want to break one off in the head...i have liquid wrench to spray it down. with and ya. i know to work it easy and all that. just any advice be good?? really dont even want to do this haha
Old Sep 18, 2010 | 12:36 AM
8t2 z-chev's Avatar
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
Re: exhaust manifold question/help
far less likely that one will twist off in the head-
far less rust and heat there. Haven't looked at a '91,
but if some of the manifold bolts have a threaded end
in order to hold a bracket,dipstick tube,ETC.with a nut
as the older thirds have,those can be a bother....
Often as you try to remove the nut,the manifold bolt will also try to turn and bend/twist the attached
brackets...
Old Sep 18, 2010 | 04:54 AM
megtom2's Avatar
Car: 1989 Pontiac Formula 350
Engine: 350 tpi
Transmission: 700
I replaced both manifolds in my 1989 a couple fo months ago and the manifold bolts came out much easier than I expected. Hope for the same with yours.
Old Sep 18, 2010 | 01:58 PM
mb2hurley's Avatar
Car: 91 camaro rs
Engine: v6 :/
Transmission: auto
ok well im half way through this project. the manifold bolts came out easy, i did soak them all night with liquid wrench thou. but apparently the power steering pump needs to come out cause there is one bracket attached to the exhaust manifold bolt. i have all the brackets unbolted from the motor and exhaust, and i dont see anymore. the 3 bolts behind the pump at the bracket, and then 2 bolts that attach the front bracket to the motor.. is there more? the pump wont budge.
Hotrodboba400
Dec 10, 2019 07:07 PM
gta892000
Aug 11, 2019 11:16 AM
db057
Apr 28, 2019 07:45 AM
86CamaroDan
Sep 29, 2015 10:08 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
