Long tube exhaust?
Old Oct 19, 2010 | 02:58 PM
irocman88's Avatar
Car: 88 IROC
Engine: carburated 350-- H/C
Transmission: TH350
Axle/Gears: 10 bolt w/ auburn posi and 3.73s
Long tube exhaust?
Hey guys, just wondering if anyone has figured out a way to run a good flowing exhaust (400+hp) with long tubes. I'm thinking of buying my old car back, but if I do, I have to be able to clear the speed bumps on base. There's no way that Strait 2.5" duals with magnaflows dumped before the axle are gonna clear. Anyone have thoughts or pictures? Maybe a y-pipe setup or a small diameter dual system run along the stock route?
Old Oct 19, 2010 | 03:18 PM
Stephen's Avatar
Car: 87 GTA
Re: Long tube exhaust?
There is thread on TGO about true duals that follow the stock routing. I think it is Summit that sells the pipes.
Old Oct 19, 2010 | 03:31 PM
irocman88's Avatar
Car: 88 IROC
Transmission: TH350
yeah but that setup is designed for the shorties, not longtubes. It's startin to look like I'm gonna have to just have a different straight dual setup built, somethin that tucks into the tunnel.... the collectors on the hedman LTs come too far back to run a y-pipe w/o having to go under the frame rails... and what's the point of that?
Old Oct 20, 2010 | 09:51 PM
Dustytrix's Avatar
Car: 1990 Iroc
Engine: 6.0
Transmission: 4l65E
Axle/Gears: 373 zexel torsen
Let me know what you find out. I am in the same situation
Old Oct 20, 2010 | 10:00 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
The collectors on any LTs come too far back to go anywhere but below the frame rails.
Old Oct 20, 2010 | 11:43 PM
irocman88's Avatar
Car: 88 IROC
Transmission: TH350
well yeah I've figured that much out. Looks like I have some saving to do. I don't have the resources to fab my own stuff right now, so I'm looking into having a shop put a cleaner set of duals on it, something that tucks into the trans tunnel nicely...
Old Oct 21, 2010 | 01:11 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Why does it have to be dual?
Old Oct 21, 2010 | 01:18 AM
irocman88's Avatar
Car: 88 IROC
Transmission: TH350
Power, sound.... Besides, I'm already between the frame rails. Why do a Y-pipe? If it's single, I need AT LEAST a 3", and that's only if I'm not goin up and over the axle. Dual 2.5" or even 2" dumped before the axle will give me a larger overall volume to work with, and less groud clearance issues. Oh single exhaust just sounds sloshy compared to duals-to me anyway.
Old Oct 21, 2010 | 12:24 PM
Tony89GTA's Avatar
Car: 89 GTA
Engine: 5.7L Supercharged
Axle/Gears: Moser 9" 3.70
When I planed out my exhaust I went for the most ground clearance I could reasonably get with long tubes and a 4" catback out back, and this is with having a t-56 tranny in the car.
some pic's for ya
Old Oct 21, 2010 | 01:14 PM
irocman88's Avatar
Car: 88 IROC
Transmission: TH350
Hmm... interesting. that's tucked up there really nice man, looks like some good work. Only thing that would make that hard for me is my stock crossmember.... I'd have to find a replacement or have one fabbed. Like the prop too, if it'll roll over a budweiser can it could most likely clear the speed bumps on base
Old Oct 24, 2010 | 05:01 PM
abray1's Avatar
Car: 90 IROC 2-92 Zs blk vert & prpl
Engine: stealth ram brodix track 1 ful port
Transmission: 700r4 4l80e
Axle/Gears: iroc 375 lokr 92 Z 277 pos vert 327
GREAT EXHAUST. What Y pipe is that? What crossmember is that? and what torque arm is that. I have the mufflex cat back with 2210s and an automatic but your y pipe and crossmember kicks a lot of but. I have a ford 9 and 4' over the axle but mine is tight at the crossmember. allen.bray64@yahoo.com
Old Oct 24, 2010 | 05:03 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Remember, he's got a manual... there's a huge difference in the amount of clearance you'll have with an automatic.
Old Oct 25, 2010 | 10:43 AM
Tony89GTA's Avatar
Car: 89 GTA
Think I'll just start a new thread with all the info, been meaning to do one anyways was just getting kind of lazy.
Frozer!!!
Jan 19, 2024 04:55 PM
87iroctheo
Dec 4, 2016 11:47 AM
formula_novice
Sep 5, 2015 03:58 AM
86iroc z Z28
Aug 21, 2015 10:37 PM
beast94
Aug 20, 2015 06:44 AM
