Hooker super comps
Car: 1990 Camaro RS (Racecar)/1991 Z28
Engine: 355 Race Engine/Stock TPI 350
Transmission: Borg Warner T5/Borg Warner T5
Axle/Gears: 4.10/2.73
Hooker super comps
What do you guys think about hooker super comp longtubes? I just picked up a set of 1 3/4 into 3" and wonder what im getting into and if i can expect some gains over 1 5/8 shorties.
Car: 1984 z28
Engine: 355
Axle/Gears: Moser 9" 4.11
Re: Hooker super comps
You better have a stout motor to put them on or your gonna lose performance and HP rather then gain it. The larger headers will shift you hp and torque up some rpm.
Its a 355 with procomp heads and a 253/253 .560/.560 cam. Its a 3-4k rpm+ motor
Its a street strip showcar that's built to sound and look like a racecar. The main goal is to scare mustangs first and go fast later
Car: 1984 z28
Engine: 355
I would stay with a 1-5/8 header and you will pickup the lower rpm torque for street use since your probably going to be driving around at 2k rpm anyway. Since you have a t5 and a 4.10 it should be pretty good on the street all ready.
Car: 1986 Camaro SC
Engine: None
Transmission: None
Axle/Gears: Moser 9" W/ spool 3.50 gears
I had them. Pain in the neck to put in but they did the job real well. If you have a cam like that than you should have already had these headers IMO.
haha well thats why im getting them the shorties just dont cut it
sounds like a good setup im just n/a
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
i had them on my old car.. very nice headers! sound was great too
awesome, thats half the battle :-)
Car: 92 camaro
Engine: 409 sbc
Transmission: TH 350
Axle/Gears: 4.10, mini spool, camaro housing
I was also thinking of buying the Hooker Super Comps. For a little extra money. I think the Ed Quay headers my be a better fit. Anyone have experience with these?
Car: 1982 Camaro
Engine: 555 BBC
Transmission: TSI Glide
Axle/Gears: Aluminum Moser 3.89
Yes, the fit is awesome for no exhaust system. They exit right before the tranny crossmember like 2210's. I have a thread concerning these on this board. I had to fab up a double hump crossmember for get exhaust to work. But then again I had no bends in my exhaust.
Car: 92 camaro
Engine: 409 sbc
I found your thread shortly after I posted that. They look great. My mind is made up.
no green
Jan 9, 2016 09:22 PM
Dragonsys
Sep 25, 2015 03:51 PM
