what exhaust for a 383 ??
Old Nov 15, 2010 | 10:05 PM
ray jr's Avatar
im building a 383 tpi street motor and was wondering if my exhaust would be ok ?? its a 3 inch factory style exhaust going into a magnaflow 3" in and 2 2.5" out .. horsepower im hoping for is 400-450 ...
Old Nov 15, 2010 | 10:39 PM
cuisinartvette's Avatar
Car: 67 ******mobile
Engine: 385 Solid roller
Axle/Gears: 4.11
Re: what exhaust for a 383 ??
LTR Id opt for a 1-5/8 primary, opinions will vary.
Old Nov 16, 2010 | 05:46 PM
AaronIROCZ's Avatar
Moderator/TGO Supporter
Wrong forum, moved to exhaust.
Old Nov 16, 2010 | 07:32 PM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
Engine: 383 TPI Procharger D1SC
Transmission: TKO600
Axle/Gears: Strange S60 3.73
For the 383 tpi im building I purchased a set of Dyno Don's 1 3/4" headers with a 3 inch Flowmaster catback.
Old Nov 16, 2010 | 09:58 PM
macertheracer's Avatar
Car: '91 RS CP now is the son's driver
Engine: CP =3.1, will get V-8 maybe someday
Transmission: stock
Axle/Gears: 3.42 posi W/ disks
the 1 3/4 is a tad large unless you plan on some 6k+ R's but it will not hurt your cruse, the 3" Flowmaster is a good choice. There is a factor in exhaust that most people do not understand, you have to tune it!! or at least understand what is going on in there. When we say tuned headers that means equal length runners to the general public, but to a seasoned mechanic, it means that the exhaust pulses reach the collector in a timed sequence. What does this mean in "the real world"? To answer this we first need to digress into the 2 cycle world. The expansion chamber works on expanding and collapsing pressure waves, expands when the exhaust port is first opened, and then collapsing before the port is closed. This collapse sucks the last of the exhaust gasses out of the combustion chamber. So now in our 4 stroke engine, the exhaust pulses operate in the same fashion, to help pull the next pulse down the pipe. continued
Old Nov 16, 2010 | 10:09 PM
Transmission: stock
to continue with my disortation, LOL,
the next phase is the pumping action pushing the exaust farther down the pipe and out. if you use pipe that is too large, it will defeat its purpose and cause more back pressure, instead of carring the "pulsed" velocity on down the pipes it will cause the exaust to have eddie currents and esentially stall the flow. I hope that this makes sense? I am in no way an expert but I do have 35 years of experimenting to draw uppon, here is what I have found out works best for me Small blocks under 327 2", 327 and above 2 1/4" , big blocks 2 1/2", This is duals all the way out the back. Do not cut them short, the sonic wave gets screwed up, "that is another discussion" go all the way to the back of the car. as far as singles for a small block 3" all the way from the Y to the back, or dual 2 1/4 stingers at the back just my 35 cents worth of opinion.
Old Nov 17, 2010 | 06:14 AM
LS4GXP's Avatar
Car: 87 Z28
Engine: AFR 383
Axle/Gears: 4:11
If you dont think a single 3 will flow enough, just throw a cutout in there and you will be fine
customblackbird
Oct 1, 2015 04:30 PM
ericjon262
Sep 11, 2015 06:07 PM
Djmathis123
Sep 8, 2015 08:42 PM
89fast5oh
Sep 8, 2015 09:55 AM
