Z28 Dual Cat Replacement - Help!
Old Dec 21, 2010 | 10:56 PM
JeffG3209's Avatar
Car: 1992 Z28 Coupe
Engine: LB9
I have a 1992 Camaro Z28 with the 305 (LB9). It has the dual cat option. One of the cats have been leaking. I go and get it welded, and it eventually leaks again. Over and over.
A few questions...
Do I have to run dual cats?
If I buy a set of headers (2055's), will I be able to use dual cats?
And finally, is there much difference in High Flow and Standard cats?
Old Dec 21, 2010 | 11:00 PM
90 camaro cj's Avatar
Car: 1990 camaro RS
Engine: 305 TBI
Re: Z28 Dual Cat Replacement - Help!
to pass emissions/inspection you will need two cats, as for the other questions i dont know
Old Dec 25, 2010 | 09:00 AM
iroc stangs's Avatar
Car: 87 iroc-z camaro
Engine: 305TPI
Axle/Gears: G92 3.23 posi
yes for emissions reason
Im not 100% positive on this but as far as I know, yes the hookers will fit
You wont notice an huge diffrence between standard cats and hi flows but they will make a diffrence and it would be recommended to go for hi flows.
Good luck
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
onefreakz
May 14, 2018 12:15 PM
TheExaminer
Aug 26, 2015 04:59 PM
Jlanz55
Aug 17, 2015 07:15 AM
