Side Pipe Kit
Car: 1985 Firebird S/E
Engine: SBC 350, mild cam Vortec heads
Transmission: Rebuilt 700R4 vette servo+shift kit
Side Pipe Kit
Would a side pipe kit from a corvette like a late stingray or even a c4 vette work on a third gen? or even would the pipes work but have to make s pipes to connect to the headers?
Car: 87 GTA
Re: Side Pipe Kit
Not as a direct bolt-on. You could start with that & modify your y-pipe to do it.
But considering you'd be modifying the emissions portion of the exhaust, it wouldn't exactly be legal to do, unless this isn't going to be a street car, then do what you want.
Re: Side Pipe Kit
everyone and their legale chatter needs to calm down since laws differ state to state in mine there is no emissions for a car 25+ years again is anyone out there attempted side pipes on a 3rd gen and what did you do to make it work?
Car: 87 GTA
Re: Side Pipe Kit
You need to calm down & realize we are just stating FACTS. Whether or not a person chooses to ignore them or not, is their choice.
If we just said "Sure...Do it." and they got busted? We'd here crap about how we told them to do something it.
So go ahead & do what you want. Why bother even asking in the first place? You should know full well that the two exhaust systems are completely different to begin with, so OBVIOUSLY it won't be a bolt-on item.
Re: Side Pipe Kit
my asking if i can use the vette kit mor or less mean does anyone know if the length of the pipe the actual side pipe would be the apropriate length for the camaro also or would it be too short/long for the side of the car
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: Side Pipe Kit
the length would probably be close, but you would just be able to use the side pipes themselves, and the ones with one inlet, not the funky ones with the 4 tubes going into them. attaching them to your headers would be up to you, and its a bit tricky especially on the driverside since the header points forward and bit.
you would probably be better off measuring the car and buying a more universal set of the appropriate size.
I had a side pipe-ish setup years ago, just glasspacks and exiting out in front of the tires, it really didnt look all that good, they just dont "work" on these cars. Also, they sit too low really, and get in the way. Even at a stock ish height, they would scrape on speed bumps and backing out of the garage.
And Stephen is 100% correct. Its a federal law to keep your emission equipment intact regardless of if you are checked for it or not.
All that aside, my largest issue with setups like this, or removing the cat(s) in general, is the smell. the exhaust will stink without them, and it can be a bit nauseating. I put cats back on my car just for this reason, and a good cat wont affect power by any amount that you can feel.
A good 3" stock routed exhaust and a good muffler will keep you legal, sound great, and offer a lot more ground clearance. It will also more or less bolt on, and you wont have to rig up something to make it work.
-Phil
-Phil
Re: Side Pipe Kit
i alrdy have a 3 inch and i think its too large feel like no back pressure losing bottom end torque and the current exhaust hits everything anyway because of how it was installed by PO
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
Re: Side Pipe Kit
there was a plain firebird about 8 years ago driving around with the single chrome side pipes from jc Whitney
it looked ok i guess not for me but it wast bad really. i have no idea how he routed the exhaust but it was functional. i would guess shortie headers and a couple 90deg bends
Car: 86 Trans Am
Re: Side Pipe Kit
what size are the sidepipes? wouldn't the end up with a higher volume than the 3" single? or are these little 2" pipes or something?
Car: 87 GTA
Re: Side Pipe Kit
Car: 91 camaro convertible
Engine: 355 c.i.
Transmission: auto 700R4
Axle/Gears: 3.90 moser 12 bolt
Re: Side Pipe Kit
the amount of backpressure an engine has determines where the power band is to some extent. some b.p. helps in low rpm range
no b.p. moves the band up into a higher rpm range
there isnt any real loss or gain just a different range
nascar teams use different exhaust headers for different size tracks
depending on if its a low end grunt track or a 10.000 rpm screamer track
also depending on the cam and the gearing in the car
and the same is true for a street car
Car: 1983 Camaro
Engine: Missing
Transmission: Missing
Axle/Gears: 9" Ford
Re: Side Pipe Kit
this past winter i played with the side pipes, honestly, i like them. now a bigger engine.
ill try to add a better pic when i get out off work.
Car: 87 iroc
Engine: 410 sbc
Transmission: tremec 3550
Axle/Gears: 30 spline 3.73
Terrell351
Jun 13, 2021 01:13 PM
toronto formula
Nov 10, 2015 06:17 AM
transaero
Aug 31, 2015 01:14 AM
