Hooker max flow exhaust sound
Old Jan 7, 2011 | 06:57 AM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
I was curious how my exhaust sounds from the outside, so I made a vid with some drive-by's. To my surprise, for an exhaust thats completely open, its actually pretty quiet and sounds stock. Basically I have hooker 2055 headers, 3" cat-back from flowmaster w/ no cat, dynomax bullet muffler serving as a resonator located just before it goes over the axle, and a 24" hooker max flow muffler, which is basically just a piece of perferated SS tube with fiberglass around it. The outlet is a single 3" on the drivers side.
The drive-bys are at 1/3 throttle, so it does start to get loud when you get on it.
http://www.youtube.com/watch?v=CHUGtG6tOwg
Old Jan 8, 2011 | 04:38 PM
Shadygrady's Avatar
Car: 87 IROC Z
Engine: 5.7 L98 TPI
Transmission: 700r4,2500 stall
Axle/Gears: G80,10 bolt 3.42's
Re: Hooker max flow exhaust sound
Thanks!sounds great.I`ve been wanting to hear one of those.I`m gonna buy one when i get some extra cash.I talked my buddy mike into buying one for his LS1/T56 combo but he hasnt installed it yet cause his exhaust isnt on the car yet.
How much do you think the resonator changes the sound.
Old Jan 8, 2011 | 05:20 PM
Car: 88 Camaro SC
Engine: SFI'd 350
The resonator helps lower the sound a little bit. its not a huge difference, but it was noticable when I installed it. It reduced it by maybe a couple of decebels, and took out some of the higher frequency sound, making the exhaust sound a little deeper.
I dont know if hooker still makes the larger 24" one, so the 18" will probably be louder than what I have as it has less internal volume to dampen the sound.
billybob6110
Sep 24, 2016 09:50 AM
deracer
Apr 11, 2016 12:04 AM
formula_novice
Sep 5, 2015 03:58 AM
FireDemonSiC
Sep 3, 2015 12:31 PM
Ducati900ss
Sep 2, 2015 09:05 AM
